Calling All Lifters
Old Jan 10, 2009 | 01:56 PM
kbaker308's Avatar
kbaker308 is an unknown quantity at this point
Default Calling All Lifters
Okay, so I'm only 18 but i am fortunate enough to have an extensive metal shop at home. I have several years experience in machining and welding. I recently purchased a 2000 Blazer 4x4, and now i want to lift it. I'm in the process of fabricating a grill guard/pre-runner bar and a roof rack, and i need to figure out my lift next. Basicly I can lift it, but since i am new to Trucks in general i don't really know what would be the best setup.
I use this truck as a daily driver so i want it to still be practical on street, but i do some off-roading too, and i would like some bigger tires. My question is how big should i go? I personally was thinking about a 3" Body lift, and a 3-4 suspension lift with a 2" differential drop, on a set of 30/9.5/15. But i am worried that it will be a little unstable in turns.
Also at what tire size should i start thinking about changing out my gear ratio?
Can i please get opinions, thoughts and advice before i go and lift.
thanks in advance
Old Jan 10, 2009 | 05:29 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
Default RE: Calling All Lifters
I Just went with a 2/2 lift and I was fine with 31s..
I hope to get the 2 inch body lift in this week...
I think a 3/3/4 and then 30s might be a bit much on the lift if you are worried about stability, you might stay in the 1-2 range on susp and 2 body you will still have ALLOT of room.
just my thoughts
check "Bytes Toy" in the sights and sounds.
Old Jan 10, 2009 | 11:18 PM
WolfPack's Avatar
If youre that good at fabricating, go solid axle in the front. The differential drop isnt quite as easy as just buidling a bracket and getting some extra bolts.
To drop the diff, youre pretty much fabricating most of the parts youd be working with in a SFA swap
Old Jan 11, 2009 | 10:35 AM
kbaker308's Avatar
Okay, thanks for the input. Do you recommend any front axles in particular? and does the SFA use leaf springs, or coil overs?, or user preference. I would also like to add that building something is no problem becasue its cheap, but i really want to keep buying stuff to a minimum, my budget is just $400-$500.
Old Jan 11, 2009 | 09:24 PM
NVANZEE's Avatar
Go with a 2in body lift and 31's. Its cheap and easy fairly easy to do
Old Jan 11, 2009 | 10:11 PM
WolfPack's Avatar
No way you'll be able to go SFA for 400-500...sorry..
But if you wanna try, start with a Dana 35 from a Wrangler. Theyre real common, but not exactly the strongest out there. More strength = more $$$. Coils vs leaf is somewhat user preference, but I think most people that go leaf spring are for cost and simplicity.
Old Jan 12, 2009 | 04:50 PM
kbaker308's Avatar
Yea, i was guessing that... after looking into i think i want to stick with IFS anyways.
Old Jan 13, 2009 | 07:11 AM
kbaker308's Avatar
Can i run the 31-10.5-15 without changing my differential gears, right now i am running stock gears.
Old Jan 13, 2009 | 07:13 AM
NVANZEE's Avatar
yes, thats what i have and i dont have any problems
Old Jan 13, 2009 | 06:15 PM
kbaker308's Avatar
I suppose I will do the 31-10.5, its kind of nice actually i check at the tire shop today and the AT 31's are $15 less then the 30's i don't know why that is, but that is nice since i need 5 new tires.
Will i see any trouble with a 2" body lift? also i haven't looked but i assume the front and especially rear bumper is attached to the frame, so i will need to make brackets to move it up?
