can i lift
Old May 20, 2009 | 07:30 PM
john96blazerLT's Avatar
john96blazerLT is on a distinguished road
Default can i lift
hi my name is johnathan, is thear any recomendations for lifting my
96 blazer 4 door awd , is it possible, i am getting mixed info, some people say i cant, some say i can, and i dont have a clue, i am thinking 2 or 3 inches, i would like 32 inch tires, if it is possible,
Old May 20, 2009 | 07:53 PM
You can do almost anything any other 4wd s-series can do.
32's are going to require some work though.
Old May 20, 2009 | 08:00 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
with 2-3" of lift youll be able to run 31's with no issues, but for 32's youll need about 5" of lift or some prettty healthy fender trimming.
Old May 20, 2009 | 08:07 PM
Default what would you recomend
i just installed large roof rack ,push bars ,winch ,off road lights on roof and flowmaster 40, but it dosent look right with factory tires. i dont plan to do any serious 4x4
Old May 20, 2009 | 08:32 PM
willjones's Avatar
Pics!!!!!!!!!
Old May 21, 2009 | 02:37 AM
okvortec's Avatar
As Mikeinwi mentioned, 32's will take alot of work, and all for 1/2" of additional ground clearance I might add. This has been discussed several times so run a quick search and you'll dig up some good info!
Old May 21, 2009 | 06:49 AM
willjones's Avatar
The jist of it is I have four inches of lift 31s on rims with 4.5" of b.s. and there are still times that I rub. Taller and wider tires would look good, but major fender cutting would be needed inorder to clear the tires.
kuojo
Oct 14, 2011 12:01 AM
Hizapitt
Mar 15, 2010 07:27 PM
f1yrod
Apr 17, 2008 03:20 PM
f1yrod
Apr 17, 2008 06:39 AM
