cant clear 30s???
can somebody please explain this to me. i have a 2000 lt blazer. i just got my buddys 30inch bf ats. i put 3 inch shackles on and cranked the bars a preety good amount. (atleast two inches). i got the offset rims (4 inch backspacing) and now i rub at the bottem quarter panels. everybody says you can do 31s with the shackle lift but im rubbing with 30s. could my shocks be toast?
i would lower your tbar crank. 1.5" max or you will probly regret it. the reason your rubbing is because your rims are backspaced to mcuh. take a picture to show us exactly where there rubbing would help. you might need to do a little trimming
It's your wheels. The 30's should fit on your stock wheels without any modification. If you're willing to cut your fenders, they should fit. I put on 31x10.5 on 4" backspacing and they rubbed in the same spot you mentioned. Even after tbar crank, I still had to cut to get them to fit. There are several ways of doing it and some look better than how I did mine
all they're designed for is controling your suspension travel.
and Matt said it best, it's all because of your off-set. i an fit a 245/65/R17 on my stock suspension '98 with just minor touching at hardlock when entering steep diveways. (those tires are 29.53" in diameter)
