currently lifting need some suggestions
Old Nov 13, 2007 | 10:32 AM
jphayes921's Avatar
jphayes921 is an unknown quantity at this point
Default currently lifting need some suggestions
puting on shackles and did a tbar crank. will I be able to fit 31x10.50 on stock rims or 265/75/15? or should I get tires for my extra set of extreme wheels with these sizes?pics later today after i get the eyebolts out of the leaf and put the shackles on.eyebolts spin, but need to lift the truck up some more to drop the leafs down to pound them out.
Old Nov 13, 2007 | 11:20 AM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: currently lifting need some suggestions
31 x 12.5 15's will fit just fine. They will rub if you come down a little hard because they still have the factory bump stop but otherwise you shouldbe good. If the bumpstop is a concern then take a look at what energy suspension has to offer for universal bump stops that you can cut to fit.
Old Nov 13, 2007 | 12:15 PM
thegr81's Avatar
Keep in mind there's always a lil friend I like to call a cutoff wheel for some trimming if you want to have no rubbing at all, just a suggestion!!
Old Nov 13, 2007 | 12:36 PM
RCars2's Avatar
True true, though the spot it rubs is more the fender lip then the inner fender so i guess if ya trimmed it and cleaned it up well that would work.
Old Nov 13, 2007 | 04:48 PM
jphayes921's Avatar
thanks guys got the darn eye bolts out with a nice drill and ghetto technique. didnt have to buy new bushings, had some left over from lifting my buddies jeep. they fit just fine. looks good have to wait till its light out to take some pics. also setup some quick disconnects for the rear sway bar.
P.S. RCars2 what did you do to mount your tire behind the back glass that looks really sweet.
Old Nov 13, 2007 | 05:58 PM
RCars2's Avatar
In short, i got creative. I have a write up for it at home that I'm just about finished with so I'll post it here in the near future so look for that and it will cover just about the whole process.
Blaine Rosemore
Tires and Wheels
Aug 18, 2014 08:49 AM
rexazz2
Tires and Wheels
Jan 31, 2013 11:35 PM
chris015
Nov 20, 2011 06:59 AM
retrorich77
Lifting Tech
May 28, 2010 02:36 AM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
