Diffrent torsoin bar heights?
Old Sep 29, 2009 | 10:33 PM
mav06's Avatar
mav06 is on a distinguished road
Default Diffrent torsoin bar heights?
Well i went under my car to crank them up about an inch, and well the passanger side bolt is over half way in and the Driver side one is way over half way out. The diffrence in the height from the tire from the fenders on either side is about and 1/8th of an inch diffrence. Any ideas on whats up?
Matt
Old Sep 30, 2009 | 02:42 AM
one.shot.one.kill.'s Avatar
one.shot.one.kill. is an unknown quantity at this point
Crank the drivers side so its the same as the passengers and then crank then both equal amounts.
Old Sep 30, 2009 | 06:26 AM
mav06's Avatar
Well if i did that then my front end would be sitting sideways lol, Its prett much level right now with the bolts the way they are. Somethings not right have no idea though. Thanks though for the thought
Matt
Old Sep 30, 2009 | 08:14 AM
You should never crank the bolts until they are both at the same depth in the torsion bar adjusting mount. You must measure the ride height to equalize it side to side.
The reason for the variation in adjusting bolt depth is due to differences in the spring rates between the two bars. For whatever reason, it always seems that the passenger side torsion bar begins to sag over the years on these trucks. You can either live with it, or replace the torsion bar.
Old Oct 1, 2009 | 06:40 AM
mav06's Avatar
Thanks for the help, that makes sense, mine must really be getting worn out because i think i have about two turns left and it will be all the way in. Thanks interesting that it would sag like that, just another wonderful blessing of the Blazer wahoo. Can i just replave the spring thats in there or the whole torsion bar?
Matt
Old Oct 1, 2009 | 08:19 AM
oktain's Avatar
The torsion bar IS the spring, so the short answer is YES lol... good luck, I've always wondered how to do that.
mafiaboy01
Oct 3, 2009 10:52 PM
imod35
Aug 14, 2009 10:21 PM
OILCOUNTRY
Feb 8, 2009 04:43 PM
toyfan1
Aug 25, 2008 01:06 PM
mudd
Jan 6, 2008 12:59 AM
