Does A Body Lift Ruin The "Ride"?
Old Nov 16, 2010 | 10:54 PM
Cojack2's Avatar
Cojack2 is on a distinguished road
Default Does A Body Lift Ruin The "Ride"?
okay, soo i have mentioned to a few people that i am wanting to lift my blazer a few inches with a body lift, like so... http://cgi.ebay.com/ebaymotors/95-97...Q5fAccessories
As i have told people this i have had a few people tell me it will ruin the "ride". is this true? what exactly do they mean by this?
thanks
Old Nov 16, 2010 | 11:03 PM
69chevelle's Avatar
69chevelle is on a distinguished road
I don't see how a body lift can ruin the ride as your only raising the body 2/3" off the frame, and not touching the suspension in any way.
A tb crank can depending on tastes, as it will stiffen it.
IMO body lift is the easiest way to gain a couple inches of tire clearence without stressing out factory suspension parts in ways they were not designed for.
Old Nov 17, 2010 | 05:47 AM
nj4x4blaze's Avatar
I have a body lift and it hasn't changed the way it rides.
Old Nov 17, 2010 | 09:11 AM
oktain's Avatar
thanks
Tell said people to pull their head out of their ***... how would a lift that doesn't have anything to do with the suspension affect the ride? Ask them that lmao. Just choose your tires right and it shouldn't ride too different.
Most people do a body lift to be able to fit bigger tires while keeping the stock ride.
Old Nov 17, 2010 | 09:15 AM
TripleBlackBlazer's Avatar
Just a slightly higher center of gravity. I can't speak from experience since I don't have a body lift, but a higher center of gravity will make it easier to roll in hard turns, abrupt maneuvers, etc. Not sure if 2" or however tall the body lift is will make a noticeable difference.
Old Nov 17, 2010 | 10:03 AM
cbr995's Avatar
What he said.^
Old Nov 17, 2010 | 11:28 AM
nj4x4blaze's Avatar
If you drive normal and not like a tool, you don't have to worry about roll overs. Again, I have no issues at all since I have a 6" lift and 2" body lift.
Old Nov 17, 2010 | 11:49 AM
jagblazer01's Avatar
Im running a 5" lift and 2" body lift and have no problems at all
Old Nov 18, 2010 | 03:55 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I have a 3 inch body lift and when i installed the the kit I did new bushings to . It rides better than ever , however the lift blocks are going through the floor mounts or crushing them . I plan on making some plates to put between the lift blocks and the body , that should fix that problem.
Patrick_Boyle
Oct 10, 2010 05:31 PM
Shalom
Sep 29, 2010 07:21 PM
Bullfrog2099
Jul 27, 2010 03:44 PM
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
dkur01
Feb 27, 2008 02:00 PM
