Dual shock absorbers
Old Dec 28, 2008 | 04:28 PM
94camaro's Avatar
94camaro is an unknown quantity at this point
Default Dual shock absorbers
What do i have to do to fit these dual shock absorbers on ablazer? I will not be doing it on a stock blazer by the way it will be after i lift it with rear add-a-leafs and a 2.375 shackle. The front will be lifted with tbar crank and the superlift 2 inch suspension lift. Will i be able to use these when i get this set up? If not could i put a body lift on it and make it?
Old Dec 28, 2008 | 05:10 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: Dual shock absorbers
the superlift 2" suspension lift is a tbar tweak and those dual shocks are for a 6" lift . If you want that much lift get the superlift 6" suspension lift or the BDS 6" lift.
Overtweaking your tbars will cause major wear issues and will ride like crap.
Old Dec 29, 2008 | 11:23 AM
94camaro's Avatar
I will not overtweak the tbars on my blazer i was just wondering if i could fit these with the superlift 2 inch suspension and tbar crank not overtweaking them. I just didnt know if anybody has these or if i could modify them to fit the lift i would have. i could also add a 2 inch front coil spacer if that would help me fit these.
Old Dec 29, 2008 | 12:17 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
ORIGINAL: 94camaro
wont work these trucks dont have coil springs (unless its a 2wd in which case you wont have tbars to crank)
Old Dec 29, 2008 | 06:54 PM
94camaro's Avatar
oh right yeah you are right. Does anybody think i could get these to fit?
Old Dec 29, 2008 | 08:30 PM
SockJock's Avatar
You won't have enough suspension travel for those shocks if that's what your asking. You need the 6" superlift suspension lift to use the double shock setup. If you are determined to use a double shock setup, try calling superlift and ask them what shocks to use with a double shock setup like that. Really the double shocks are for controlling a much larger tire(33" and up)
davidh
May 20, 2010 07:44 PM
01Jimmy
Apr 9, 2010 05:55 PM
Marcin
Jun 4, 2008 02:19 PM
cain45
18
Nov 24, 2007 08:16 PM
cain45
Nov 21, 2007 12:33 PM
