easy way to lift
Old Jan 16, 2011 | 05:40 PM
awbolton66's Avatar
awbolton66 is on a distinguished road
Default easy way to lift
I have 2000 chevy blazer I was wondering of a cheep way to lift it up so i can 31x10.5 tires with my stock rims.
Old Jan 16, 2011 | 05:43 PM
rriddle3's Avatar
*Moved to 'Lifting Tech'. The 'New Member' section is only for introducing yourself and your ride, not for asking technical questions.*
Old Jan 16, 2011 | 05:49 PM
awbolton66's Avatar
Default Body lift need some help
I have 2000 chevy blazer i want to get 2" body lift 4 it is very hard to put on and i want to put 2" shackle kit to and crank the tbars 2"
Old Jan 16, 2011 | 06:40 PM
warthogdriver's Avatar
body lift is easy, just follow inst. and take your time. it took me an afternoon.
the shackles are far more a pain in the a$$ then the body lift in my opinion.
t-crank i wouldnt go more then 1.5 inch, easy to do.
search there is a how to floating around here somewhere for t-crank and shackles.
Old Jan 16, 2011 | 06:49 PM
awbolton66's Avatar
I need to get new ball joints to 178000 miles orginal ones on it you think i should go with more preformances one if i crank the tbars
Old Jan 16, 2011 | 07:01 PM
i would go with moog ball joints,
the cv boots will most likely slip off, when they do, you can use an adjustable clamp to hold them down after repacking them. i did that over a year ago and no issues. cheap 3 dollar fix.
Old Jan 16, 2011 | 07:06 PM
awbolton66's Avatar
what is the best body lift to go with and cheaper i would like 3" body lift but i cant find on 4 my blazer
Old Jan 16, 2011 | 07:38 PM
check summit or ebay, you wont be able to find a 3" lift for second gen.
i don't believe anyone even makes one.
Old Jan 16, 2011 | 08:25 PM
CarThrower's Avatar
CarThrower is on a distinguished road
What are all the lift sizes they make for 2nd Gen?
I've been dying to lift mine, but I don't know all that much about it..
Old Jan 16, 2011 | 08:40 PM
awbolton66's Avatar
they only make 2 inch all i can find from
190 to 250 dollars
