easyest and cheapest way to get about 3 inces on your rig
Old Jul 30, 2012 | 07:45 PM
Harlan Jentz's Avatar
Harlan Jentz is on a distinguished road
Default easyest and cheapest way to get about 3 inces on your rig
first you have to put it up on a frame lift trust me it helps
things your gonna need
1) 4-1.5 inch coil spacers
2) 4-new shocks 3 inches longer
front=
okay once you have the truck on a lift take all 4 wheels off then in the front take off your front shocks now you can loosen up your coils and fit one under and one over each coil instal new shock tighten everything up and your done with the front
rear=
ever notice how your axle is actually above your rear leaf springs well heres where that changes first take the old shocks off then loosen up your u bolts and your gunna want a jack for this you want to take your rear end and one side at a time bring it under your leafs and drop it on a jack then you can bring it up to the bottom of your leafs and mount it on it might take some figuring but now you have to find a way to put the new shocks on the rear put all 4 wheels back on and your done
Old Jul 30, 2012 | 08:10 PM
slowsinglecam's Avatar
slowsinglecam is on a distinguished road
But Blazers dont have coil springs. They have T-Bars.
Old Jul 31, 2012 | 12:46 AM
Thogert's Avatar
2wd blazers (and s10s) have coils in front.
Old Jul 31, 2012 | 05:28 AM
well that's weird i think my 89 has coils in the front
Old Jul 31, 2012 | 05:38 AM
and actually just siting here reading it you probably don't need new shocks for the rear and if your front end does have t-bars well its a nice way to level it out when your towing something
Old Jul 31, 2012 | 06:48 AM
Really? Learn something new every day lol.
Old Jul 31, 2012 | 11:11 AM
neo71665's Avatar
S-series 4x4s all have torsion bars. 99% of the 2wds have coils. There was a 2wd zr2 model that used torsion bar suspension. Was the same as its 4wd brother with the axles replaced with stubs and 2wd trans. GM also done the same thing on some import 2wds.
Guys that lower 4x4 models (and some typhoon owners) do the same mod of removing the axles and making stubs to convert their 4x4 (or awd) to 2wd to get more clearance for lowering.
Old Jul 31, 2012 | 07:50 PM
Vahomboy's Avatar
Vahomboy is on a distinguished road
Dang! You're talking about Blazers. I thought I had a surprise for the ol lady...LOL!
Old Aug 1, 2012 | 07:06 AM
okay do the t-bars run along the frame or what cuz the onlything i found on my 89 front end was the 2 shocks
Old Aug 1, 2012 | 07:36 AM
nunya's Avatar
nunya is on a distinguished road
When your just flipping the axle to under the leafs, what are you doing about the spring perches?
