Factory Ride Height Specs
Old Aug 11, 2011 | 05:25 PM
weazel's Avatar
weazel is on a distinguished road
Default Factory Ride Height Specs
Does anyone have these specs and where on the body do you measure these from.. Im trying to get a starting point as to how much lift Im gaining. Thanks
Old Aug 13, 2011 | 09:43 PM
Karcinagin's Avatar
Karcinagin is an unknown quantity at this point
same here, I got 130k of sag and if I do the t-bar lift i want to know how far i can take it.
Old Aug 14, 2011 | 03:30 AM
Zanders's Avatar
Zanders is on a distinguished road
Saved this in my favorites for myself: https://blazerforum.com/forum/tech-a...rements-38019/
Old Aug 15, 2011 | 01:13 AM
Thogert's Avatar
I read that and it just confused me, it's like some of the info is missing.
Old Aug 15, 2011 | 07:33 AM
All of the info is there. I just used it not too long ago to reset the ride height on my friend's Bravada. What part was confusing to you? Maybe we can help.
Old Aug 16, 2011 | 12:11 AM
Thogert's Avatar
I'm confused on whether those pics are looking at the front or back of the control arm, and on a pic there is a 1, a 2, and a 3 that tell you what the parts are and I can't find anything for the 3. I don't know, I looked on mine but couldn't see where the mesurments were supposed to be taken. I may just be an idiot though. It wouldn't be the first time
Old Aug 16, 2011 | 08:14 AM
3 is the actual dimension. It doesn't really matter if you are looking at it from the front or back. The best way I have found to get this measurement is to use a 2' or 3' level. Set it up against the bottom of the ball joint, level it, then measure up to the control arm mounting bolt.
Old Aug 16, 2011 | 11:11 PM
Thogert's Avatar
Oh ok, thanks. I'll give that a try.
Old Aug 20, 2011 | 09:01 PM
weazel's Avatar
How did your set up go? I am getting a set of different torsion bars to replace my wore out ones. So basically just wondering if you were able to get close with your measurements.
Old Aug 21, 2011 | 01:10 AM
Thogert's Avatar
If you are talking to me, my front end is ~2.5 in. lower than it should be. I'll have to crank them to see if they are sagging or just not as tight as they should be.
