gear availability and axles.
Old Apr 1, 2010 | 11:49 AM
dougg01's Avatar
dougg01 is on a distinguished road
Default gear availability and axles.
So my Jimmy is now on 31s and has 3.42s. With the 3.06 1st gear that's not horrible, but I am used to more off the line and prefer to be a bit more in the torque band.
It's nothing I'll do tomorrow, but I'd like to run 3.73s. I have a ring and pinion for the rear on hand (we have 2 4th-gen f-bodies and another S-series in the family). I know nothing about the front diff on these things. How hard to change gears on it and where do you get 3.73s for them...?
My wife's suburban has 265/75-16s (~32") and runs 4.10s and it works good, but can spin easily in the slippery stuff even with it's 7,000lbs of blubber. I'd not want to go that far. I think 3.73s would be about right and if I remember right it's the standard issue for the ZR2s...
So.....has anyone done this....swap the front diff gears to 3.73s...? Where'd you get them..? How much of a PITB was it...?
Also....who has got aftermarket axles for their 7.5...? We've gone 11-ohs on a 7.5 torsen using factory axles with a cap girdle and arp studs, but that isn't with a solid locker on a 5,000lb truck caught in a tight space. The stockers might be up to it, but I don't have any personal experience on when they fail since the only part I've broke on a 7.5 in over 12 years (again - autoxing, hard driving, and drag racing) has been a fragged torsen (worm gear failure leading to catastrophic fubar).
Old Apr 2, 2010 | 10:46 PM
abig84's Avatar
is this a fullsize blazer? if so the fronts are kinda iffy. ive got the axle shafts out from anywhere taking a hour to like 5 depending on rusty parts and broken stuff. you have to dissemble hubs and bearings and pull the shafts out.
Old Apr 3, 2010 | 12:31 AM
old skool luvr's Avatar
i'm thinking it is a "S" series, with the reference to the ZR there. they all came with the option of 3.73's as well-my 4 door has 'em in there from the factory.
i mentioned that bit of info for you, since it may just be cheaper (and easier) for you to swap the whole front diff.
Old Apr 4, 2010 | 11:21 AM
AJBert's Avatar
To change out gears in the front diff you first have to drop it out of the vehicle. It is a split case and there is just no way to open it up until you drop it.
ImScrewed92
Jun 9, 2010 04:47 AM
Gearhedd
Jan 5, 2010 08:03 PM
nygneonkurtis
14
Mar 8, 2009 07:35 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
