Suspension Tech Have a question about modifying your suspension? Ask it here.
ZR-2 axles vs. Standard axles
Old Aug 30, 2005 | 12:29 AM
webbyj883's Avatar
webbyj883 is an unknown quantity at this point
Default ZR-2 axles vs. Standard axles
I have a stock 2 door blazer and I recently lifted the front of my truck the cheap way by cranking on the torsion bars 10 full turns on both sides. . . now my front axles are making noise on the highway and blowing grease all over the place, so I brought the front down 4 turns on either side. I went to the store to buy replacement axles and wondered if the ZR-2 axles would fit better in the front of my truck if i cranked up the front end again. Auto zone or advanced auto have no clue and I don't want to buy them to find out the hard way.
Anybody know the difference between the ZR-2 axles and the standard ones? And is it possible to use ZR-2 axles with a regular blazer, if so, what mods to i need?
Old Aug 31, 2005 | 12:00 AM
Nutt151's Avatar
Nutt151 is an unknown quantity at this point
Default RE: ZR-2 axles vs. Standard axles
sorry,dont have an answer for ya,but just wanted to show ya someones listning. so many posts go up in here with like 50 readers and 0 replys kinda sucks but hey. good luck with the axel prob.
Old Aug 31, 2005 | 11:38 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
sorry, man no clue. id jus go with the stock axle shafts.
Old Sep 1, 2005 | 02:17 PM
webbyj883's Avatar
well. . . the stock axles have a lifetime warrantee. . . so i guess if i'm willing to do the work, i'll just replace them a lot. Thanx anyway
Old Sep 6, 2005 | 11:16 AM
ohsingltrakr's Avatar
ohsingltrakr is an unknown quantity at this point
I know there's a difference in the axles as I couldn't find a zr2 axle when I needed one, the standard one was no problem. My favorite parts house here said they were on backorder with no projected delivery date. He said it was a frequent problem with the zr2. You might have a hard time finding zr2 axles rebuilt. The outer bearing I believe works with either axle as I was told there was just one parts number for that. I doubt the output shaft is different from the front diff. but I really don't know that. Makes you wonder if they wouldn't be interchangeable but it'd be a lot of hassle to find them and tear your front end apart to compare.
Old Sep 6, 2005 | 02:25 PM
webbyj883's Avatar
i found out the difference. The ZR 2 axle is around 2-4 inches longer than the standard axle between the joints. The shaft input and output to the wheel are identical. Since I didn't agressively change my front end, i stuck with the standard axles.
Old Sep 9, 2005 | 02:15 PM
webbyj883's Avatar
My axles are still making noise. I'm pretty sure it's because the torsion bars are raising the front end a little too much. I really don't want to have to bring the front end down. . . stock with the blazer is just too d*mn low. Any suggestions?
buschmaster
Mar 13, 2012 09:10 AM
OldJr88
Aug 13, 2009 12:13 AM
Bad Ramer Jamer
Sep 23, 2008 05:53 PM
ron768
Mar 16, 2008 05:03 PM
hls811
Jan 17, 2008 10:40 PM
