good body lift?
Old Dec 6, 2008 | 08:40 PM
  #21
NVANZEE's Avatar
Default RE: good body lift?
the last thing on the alerts says "Rear bumper with integrated factory tow hitch cannot be raised on some S15 models"
Old Dec 6, 2008 | 08:44 PM
  #22
stevo's Avatar
stevo is an unknown quantity at this point
so if your saying that the factory hitch in on the bumper instead of below it
then no you couldnt use the factory because of the mounts being longer which would make it have less support
in other words, you run the risk of pulling your bumper off
correct me if im wrong
Old Dec 6, 2008 | 09:34 PM
  #23
NVANZEE's Avatar
no my hitch is bolted to the frame so i think i will be ok
Old Dec 6, 2008 | 09:56 PM
  #24
stevo's Avatar
you should be
i dont see why there would be a problem
Old Dec 7, 2008 | 11:55 AM
  #25
WolfPack's Avatar
Negative. The body lift only works if you have a Class I or II hitch. A Class III hitch uses all for frame bolts and has integrated bumper brackets for that reason. This means you simply cannot install the body lift bumper lift brackets. I would say based on BDS's instructions that the factory hitch was Class II. (never heard of welding an aftermarket hitch though...mine definitely isnt )
Heres a pic:
The only solution I've been able to come up with is to cut the hitch's bumper bracket (so it doesnt affect the integrity of the hitch), and weld either them or the kit brackets 2' higher..but I've been rolling hitch-less for a few months since my body lift install [&o]
Old Dec 7, 2008 | 12:09 PM
  #26
stevo's Avatar
ok thanks
i personally dont have a hitch on my truck, but im sure you helped alot of people who do
Old Dec 7, 2008 | 06:58 PM
  #27
NVANZEE's Avatar
how can i tell what class hitch i have
Old Dec 7, 2008 | 07:02 PM
  #28
WolfPack's Avatar
It should be pretty clearly labeled, either with a class rating or with a weight rating.
A trailer hitch typically bolts to the chassis of the vehicle. In the U.S. there are a few common classes: I, II, III, IV, and V that are defined by the SAE.
Class I - up to 2,000pounds (907kg), and II - up to 3,500lb (1,588kg), are for designed for light loads.
Class III - up to 5,000pounds (2,268kg), and IV - up to 10,000lb (4,536kg), can accommodate much larger trailers such as campers, boats, etc.
Or if you can see the hitch mounts like in my pic, Class II only utilizes the forward most 2 bolts (closest to shackle), and you retain the stock bumper bracket. Class III is like my pic. Havn't seen a class IV installed on a blazer
Old Dec 7, 2008 | 07:18 PM
  #29
NVANZEE's Avatar
mine no longer has a label since its been repainted so ill have to look at it. Thanks
Tinted
Lifting Tech
Dec 31, 2011 11:08 AM
2000blazerdudeman
Lifting Tech
13
Feb 25, 2010 11:59 PM
gtmci84s
Lifting Tech
Feb 16, 2009 11:25 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
