Has anyone tried these??
Old Aug 18, 2009 | 08:33 PM
mdehoogh's Avatar
If it says 2" lift shackle, then it will lift you 2". A 2" lift shackle is 4" longer than stock. If one side moves up 4" and one side stays fixed, the midpoint (where the axle is mounted) will move up 2"
The lift is half of the difference in length between stock and aftermarket.
3" difference results in 1.5" lift
4" difference results in 2" lift
5" difference results in 2.5"
37" difference results in 17.5" lift
Old Sep 15, 2009 | 08:39 PM
warthogdriver's Avatar
i used the autozone shackle set (cheap bastard) doubled them up though and bought new hardware, doubling them made included hardware useless.
i am happy with them, about a month now (daily driver no serious off-road) adds up to about 1/2" steel on each side of mount. i fig. should be fine for what i am doing.
i was also happy with the lift they provided.
Old Sep 15, 2009 | 10:21 PM
elementtrev's Avatar
elementtrev is on a distinguished road
i wouldnt even think about buying those cheap pos' from autozone. get either daystar shackles, fabtech shackles, somthing alot stronger than the ones you posted.
here are 3 diff shackles lifts that woub be good.
http://www.shop.synergyoffroad.com/p...&categoryId=10
(^ these are made by a guy from zr2usa.com) also the ones i have on my BlaZeR 2.
Old Dec 27, 2009 | 09:34 PM
JS_blazer's Avatar
JS_blazer is on a distinguished road
Well, you could always buy the cheap ones, and mod them to be stronger.
Old Dec 28, 2009 | 11:42 PM
neo71665's Avatar
I just made my own out of 1/2 thick steel. Drilled enough holes to have anything from 1 inch of lift to 4. Pic is of the rear end maxed out just to see what it would look like, I ride around with it on 2 inches.
EricR
Apr 7, 2012 03:04 PM
RebelJimmy96
Tires and Wheels
Dec 4, 2009 05:52 PM
4x4blazerguy
Mar 13, 2008 05:29 PM
igot10pinitis
Jun 30, 2007 01:42 PM
