How to do a t-bar crank ???
Old Dec 7, 2011 | 10:18 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
Default How to do a t-bar crank ???
Just wondering if anyone can give me a step by step guide on how to do a t bar crank I know I have to jack the truck up but where also I am kind of limited on jacks and stands I only have 1 of each is there anything I can substitute for either? Also I am unsure of where exactly the t bar is? What tools do I need? what is the maximum I can crank it without damaging anything? also does the t bar crank only lift the front or just the rear or does cranking it lift the entire vehicle? This would be my 1st time ever doing a t bar crank and I want to make sure I do it right and don't mess anything up. I would like to do a 1.5" crank.
Old Dec 7, 2011 | 11:05 PM
Thogert's Avatar
Just follow this and you should be fine.
https://blazerforum.com/forum/tech-a...r-crank-37078/
Old Dec 7, 2011 | 11:17 PM
xgiovannix12's Avatar
tbar crank its just the front follow the link above it has all the information you need
and for the rear go with 2 inch lift shackles
make sure there 8 inches between holes
the stock ones are 4 inches between holes
every inch is 1/2 lift
Buddykitchen
Dec 10, 2016 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
DreadPirate_Davey
Lifting Tech
Dec 21, 2009 06:13 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
Bgray
Suspension Tech
Sep 10, 2006 04:45 PM
