How High??
Old Dec 30, 2009 | 04:16 PM
tony991's Avatar
tony991 is on a distinguished road
Default How High??
When you lift a blazer, how high can you go with a suspension lift without having to mess with the drive shafts?
Old Dec 30, 2009 | 04:23 PM
zedartwo's Avatar
All depends on what 4x4 system you have. Most companies will state that "Drivetrain/Drive-shaft modification required with 4-button Insta-Trac"
But I'm sure someone will tell you an average of what can be accomplished.
Old Dec 30, 2009 | 07:33 PM
butters's Avatar
butters is an unknown quantity at this point
https://blazerforum.com/forum/lifting-tech-44/start-here-lift-kit-list-16186/
this thread talks about it, you can go pretty high without any problems
Old Dec 30, 2009 | 08:11 PM
tony991's Avatar
Would there be any problems with a 7.5-8 inch suspension lift?? (1987 S-10 Blazer)
Old Dec 30, 2009 | 11:29 PM
NVANZEE's Avatar
im not positive but i think the biggest suspension lift it 6in. I know it is for the second gens. Unless you are doing a solid axle swap.
Old Dec 31, 2009 | 10:10 AM
tony991's Avatar
I Have a 6" Lift (not installed yet) and i was thinking of putting 2" lift blocks in the rear and 1.5" Tbar crank. with the lift..
Old Dec 31, 2009 | 12:40 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
Default 6''
I believe nvanzee is right. around 6 inches is the maximum maybe a little more for the 2nd gen, if you want to go more you can get the extensions for the driveshaft.
Old Dec 31, 2009 | 09:46 PM
tony991's Avatar
ok, thanks guys...
Old Jan 16, 2010 | 08:05 PM
tony991's Avatar
Would it be possible to take a longer drive shaft out of a similar truck and throw it in the blazer? something that matches the yoke.. just an idea.. And I've heard about the CV drive shafts, are those pretty good or do they bind up??
mcdevin1973
Oct 5, 2014 02:52 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
Jun 27, 2005 04:54 PM
jimmyone
Jan 27, 2005 06:32 PM
reggie4828
Engine & Internal
Jan 6, 2005 10:58 PM
zero psi
Suspension Tech
13
Oct 8, 2004 07:05 PM
