i need a measurement off a ZR2 please
first off, my front sits 3/4 an inch higher in the front & it cannot be lowered any, the keys are all the way down
drivers side leafs are sagging about a 1/2" lower than the passenger... which in turn is raising the front right. Sooo.. since I already got the t bars off a low mileage Z, figured I might as well get the leafs off the same 33,xxx mile truck.
found these crawlin the web. notice the ZR leaf eye hole is on the bottom compared to the NON-Z which is on top. I think that ought to be about an inch height increase & i will raise my spring rate by about 600lbs
What I need is the measurement between the leaf spring mounts on the frame, hanger bolt to hanger bolt. I also need the width of the leafs themselves, just to be sure they will fit. TIA
