k10 blazer
Old Sep 25, 2010 | 03:25 PM
varner's Avatar
varner is on a distinguished road
Default k10 blazer
I am just getting into four wheeling. First of all is the suspension on K5 and K10 the same? I have an 1981 K10. I just riased the rear by switching the rear hanger. I need to find out how to lift the front. I am raiseing it four inches. Can i use a block under the leaf spring or is there a better way to do this with out buying a kit? I also thought of useing a helper spring.
Old Sep 25, 2010 | 05:06 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
on your title is says k10 doesn't it? its a k5 blazer. you can go zero-rate or i've seen guys go with longer shackles. the best way is to get different springs that have more of an arch. alot stiffer though
Old Sep 26, 2010 | 11:33 AM
84BlazerS10's Avatar
I'm not up on K series blazers but Isn't the K10 a 4wd short bed truck from the 60's?
If that's the case I know they both had independent front suspension.
Old Sep 26, 2010 | 07:16 PM
abig84's Avatar
yeah the pick up and k5 stuff up front is the same. im not quite sure about the back. i have k5 springs up front on my k30. its not recommended to use blocks up front cause they can possibly be shot out in a high torque situation. unless you want something small like a one inch. you dont have to buy the whole kit you can buy just the front springs. i bought mine used off ebay
jingram20
Sep 11, 2014 01:09 PM
sailorjerryy11
Aug 15, 2013 01:32 PM
Woot!
Mar 14, 2008 09:46 PM
eskilm
Nov 4, 2006 09:04 PM
