Leveling front end
Old Aug 12, 2012 | 09:33 PM
muntyv's Avatar
muntyv is on a distinguished road
Default Leveling front end
I recently lifted my 01 Blazer 4x4 LS 4dr with a 5" BDS 2" body lift and added leaf springs to the rear and put on some 35s
It is still got a little tilt because the leaf springs added about 3" instead of 2" like I hoped. I have had some rubbing issues with the 35s turning and hitting a bump even though I trimmed the fenders pretty well. In addition to trimming more, what choice should I pick for leveling out the front
BTW this rig is for purpose not just looks
Old Aug 12, 2012 | 10:49 PM
Rottidog's Avatar
Well whatever car is parkerked behind it their roof gives the blazer a sweet hood buldge lol.
I can see where you need to trim the fenders more, that little angle should be more direct/straighter IMO.
Are those soft 8's or pro comps? Either way you may want to get different rims for the offset.
T bars are the way to level the front, possibly back the bolts out & re-set them equally. You will or should have to get an alignment afterwards however. But if doing that levels the front then I'd say it's worth it.
A little rake to a blazer is good IMO. Most after a few years have a saggy rear end & it helps with carrying loads/towing etc.
BTW do you mean level the front as in equal height side to side or the front rake it has?
As I said I love the slight rake, it looks really good IMO.
Old Aug 13, 2012 | 12:45 AM
tibby's Avatar
Default .
The truck looks good! But as far as the rubbing issue up front, you have limited options. Your torsion bars may be able to be adjusted a tad bit depending on how close they are to being maxed out and also depending on alignment issues. The only other things I can think of would be changing out the wheels to a different backspacing like Rotti said or getting extremely stiff shocks for the front if yours are kind of mushy.
T...K21
May 25, 2013 10:26 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
NYBLAZER
May 10, 2010 01:22 AM
akcalvin
Lifting Tech
14
Mar 19, 2009 10:08 PM
Rp9110
Jan 5, 2008 11:27 PM
