lift
Old Nov 6, 2008 | 06:53 PM
Default RE: lift
Spot on!
Old Nov 6, 2008 | 06:56 PM
Blazin NC's Avatar
Blazin NC is an unknown quantity at this point
Default RE: lift
Guys, thanks for the correction, I was aware that the 2" kit is not worth it, I just got my reason wrong.... so what do new upper control arms do??? anything?? or is it just a way to make more money??
Old Nov 6, 2008 | 08:21 PM
WolfPack's Avatar
Default RE: lift
New upper control arms let you be able to align the wheels, and correct the balljoint overwork that lifting with the stock arms causes. The 2' kits used to come with shock relocation brackets so you didn't need the longer shocks (and to prevent shock top out), but it would appear the balljoints were a much more pressing issue than shock position.
Old Nov 10, 2008 | 04:27 PM
68novabbc's Avatar
68novabbc is an unknown quantity at this point
Default RE: lift
So, how big of a chore is it to do a 2" body lift?
Old Nov 10, 2008 | 09:28 PM
WolfPack's Avatar
Default RE: lift
Its really only 12 bolts, a couple spare parts
How mechanical are you?
Old Nov 10, 2008 | 09:33 PM
68novabbc's Avatar
Default RE: lift
Well, whats it consist of other than the cab mounts and the bumper mounts?
and to question my mechanical skill? well these are my two of my other cars.I have just never piddled around with trucks or body lifts to be specific.
http://i149.photobucket.com/albums/s...ovaBBC/039.jpg
Old Nov 10, 2008 | 09:51 PM
WolfPack's Avatar
Default RE: lift
Sexy
I think you can handle the body lift then..
On the 98, its a little more involved than just the mounts. You have to cut and extend the fuel filler neck, notch the rear bumper, notch the front valence, loosen a whole lot of ground straps and body clips, and flip the oil filter around (and install a drop bracket...but very easy). Its more time consuming that difficult. You have to loosen and remove all the previous mentioned parts...then jack up one side, install spacers but not tighten bolts, go do other side and tighten bolts, then come back to the first side and tighten. Then its all getting everything lined up and reconnected.
Ive got one thread on my install here with some info, and heres the OFFICIAL DIY BODY LIFT THREAD.
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
