Lift Kit
Old 12-22-2008, 06:13 PM
mdehoogh's Avatar
Default RE: Lift Kit
What are you trying to achieve by lifting it? I've seen people ask for suggestions on how to lift it and once they do, they find they can't fit the size tire they were wanting.
Once you lift, are you going to get larger tires? If so, will you want new wheels?
You need to factor everything together so you know exactly what you'll need to do before you actually do anything.
Old 12-23-2008, 06:41 AM
BGwood88's Avatar
BGwood88 is an unknown quantity at this point
I would just go with t-bar crank and lift shackles. its the cheapest.
Old 12-23-2008, 06:46 AM
nj4x4blaze's Avatar
So many threads asking the same questions.
https://blazerforum.com/m_123415/tm.htm
Old 12-23-2008, 12:36 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
i wanted some more clearance, maybe some bigger rims later on and tires. idk this is my first step. i guess i will just figure it out myself or forget about it.
Old 12-23-2008, 05:39 PM
mdehoogh's Avatar
ORIGINAL: Numba1Sean
While lifting it would push the truck up higher, you won't gain any real clearance without larger tires. The axle will still be in the same place as it was before lifting. Tires are what get you ground clearance. Lifting just allows room for bigger tires.
If you really just want the cheapest route, crank the t-bars and get shackles for the rear. Parts will wear out eventually even if you spend extra on a 2" kit from Rough Country or Superlift. Depending on age and how much longer you'll have the truck, you'll need to replace front end parts at some point.
Old 12-24-2008, 03:29 AM
Numba1Sean's Avatar
so what would be the largest before lift and then after lift? And no way am i going the cheap route, because cheaper isnt always better < learned the hard way.
Old 12-24-2008, 04:51 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
this thread should tell ya what you want to know about what size tires you could fit both pre and post lift https://blazerforum.com/m_10637/tm.htm
bigdaddykane93
02-24-2013 02:30 PM
Jkrumm
Lifting Tech
02-17-2011 04:35 PM
jjsmith1228
10-31-2010 03:56 PM
ericthughes
Lifting Tech
10-13-2010 10:56 PM
Blazer man
05-11-2005 04:29 PM
Quick Reply: Lift Kit
