lift kit questions
Old May 6, 2009 | 08:40 PM
harpnicholas's Avatar
harpnicholas is an unknown quantity at this point
Default lift kit questions
i have a 93 s10 blazer and i want to put a lift on it but all the lift kits i found went from 2 in front and 1 in rear to 6 front and 5 rear. My question is does any one know of a way to put the leaf springs on the rear on top of the axle rather then the shackle lift. i would like any help i can get thanks.
Old May 6, 2009 | 08:42 PM
Search helps... The spring over axle flip has been discussed before. What are you trying to accomplish? A particular tire size in mind? What is your budget?
Also, please limit your questions to one thread.
Old May 6, 2009 | 08:55 PM
im just trying to get 31 10.50 on it but with enough clearence to not hit when i take it 4 wheeling it has 255/75/15. my budget is what ever it takes
my bad on the two posting i am new and did not c this one first
Old May 6, 2009 | 08:59 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
as kyle stated, use the search function i guarantee youll find your answer quickly. theres even a sticky thread in the wheels/tire section that tells you wat lift youll need to run a certain size tire.
Old May 18, 2009 | 08:10 PM
ooodavie's Avatar
ooodavie is on a distinguished road
i have a 3inch bl and run 31 10.5 and have no problem and i go wheeling every weekend
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
93blazernick87
Lifting Tech
Mar 22, 2010 12:41 AM
TATBLZR
Lifting Tech
May 17, 2009 06:32 PM
harpnicholas
May 6, 2009 08:35 PM
