To lift or not to Lift.
Old Jan 26, 2014 | 08:40 PM
AGodlyCanuck's Avatar
AGodlyCanuck is on a distinguished road
Default To lift or not to Lift.
So, i am thinking of installing a 2.5" body lift to my 2000 blazer.
I am wondering though... from Stock, what size tires would a 2.5" lift allow me to mount?
I believe i have 30's on it now...
EDIT: They are probably not 30's
235/75/r15 Can't sya for sure =.=
And i am wondering if it is even worth it or not.
As i do like the subtle stock look of things.
Plus the vehicle has 300,000kms (192k miles?)
so i am trying to avoid the Torsion bars.
But whta you guys suggest will be seriously considered :3
I mostly need Ground CLearance because i like to explore
Old Jan 26, 2014 | 10:38 PM
LeWhite's Avatar
192 miles? Think you better leave well enough alone
Old Jan 27, 2014 | 12:59 AM
Why? its got no rust or anything...
And the engine and tranny are being swapped in the next couple months XD
from a vehicle with 80k
Old Jan 27, 2014 | 01:31 AM
Diaita's Avatar
I wouldn't do a body lift. If you have 30" tires now, and you can fit 31" tires with the body lift, you are gaining only ½" of clearance. Worth the effort? With a 2½" suspension lift and the same tire size increase, you have gained 3" of clearance. 2¢
Old Jan 27, 2014 | 01:35 AM
Now that i think about it... I am probably wrong about the tire size...
I havent driven the vehicle in 7 months and its parked at my parents. an hour away. hmmmm :/
Old Jan 27, 2014 | 01:46 AM
Diaita's Avatar
Wrong about?
Old Jan 27, 2014 | 02:47 AM
Wrong about?
Sorry about the tire size.
Been going 13/14 days of straight work lol
Minimum wage is a terrible thing 0.o
As for pics or reference. That is all i have.
Old Jan 27, 2014 | 04:34 AM
newguy's Avatar
Dont listen to Whitey , he lowers trucks! I have 220,000 and did a body and suspension lift. Pretty sure i can 32s no problem. Body lift makes it easier to work on stuff underneath also
Old Jan 27, 2014 | 01:24 PM
Diaita's Avatar
The tires look like about 27-28" at a guess.
Old Jan 27, 2014 | 07:45 PM
El_Beautor's Avatar
My 2 cents: A body lift gains you zero ground clearance. It only gains you tire clearance. Larger tires gain you 1/2" ground clearance for every 1" taller tire. Personally I don't see much value in only doing the body lift to fit bigger tires.
If you want to lift your truck (and understand the effects this will have) then start with a suspension lift (RC 2.5" lift or even just a reasonable 1.5" t-bar crank and shackles) and see if you can fit your desired tire size. Most people can fit 31's with this setup, and you can add the body lift to that if you're having problems with rubbing on the fenders.
