lift problems! help!
REAR:
i would go with 2" lift shackles in rear....50 for the pair
you will most likely need new bushings on the rear springs....20.00 for the pair.
FRONT:
torsion bar lift the front 1.5" MAX.
easy to do...look for the how to .....best all this parts free.
some say it will wear the front prematurely but i did mine along time ago and only problems i have had were of my own doing.
only minor issue i know that could happen is your cv joint boots might slip off, but that is a cheap and easy 4.00 fix.
do a little research around here and see what catches your eye and budget.
FRONT:
upblazer95
Apr 4, 2009 08:27 PM
