lift using torsion
Old Apr 4, 2008 | 11:23 PM
dubb_05's Avatar
dubb_05 is an unknown quantity at this point
Default lift using torsion
I was thinking of lifting my blazer by torsion bars and shackles. Will that give the same or close height as a ZR2? I was told the ZR2 is lifted 2" from factory and from the other posts on here ive read they sayu can lift by adjusting torsion up to 2".
Old Apr 5, 2008 | 09:33 AM
Sterling's Avatar
Sterling is an unknown quantity at this point
Default RE: lift using torsion
this should be under Suspension tech: lifting tech subforum.
and 2" crank on your torsion bars, not recomended, Youd be better off cranking 1 1/2" and buying an actual lift kit (you'll end up spending the same amount on repairs unless you're lucky)
Old Apr 5, 2008 | 01:36 PM
dubb_05's Avatar
my bad ill repost it there...
Old Apr 5, 2008 | 03:43 PM
*Moving to Lifting Tech* - No need to repost the thread, we can simply move this one.
Old Apr 5, 2008 | 04:51 PM
dubb_05's Avatar
Thanks for the move swartlkk
Old Apr 5, 2008 | 04:53 PM
dubb_05's Avatar
Any answers?
Old Apr 5, 2008 | 05:30 PM
tjwiens91@hotmail.co's Avatar
tjwiens91@hotmail.co is an unknown quantity at this point
DO NOT CRANK TORSION BAR 2"!!!! you will be blowing parts. 1 1/2 yes but not 2
Old Apr 5, 2008 | 06:17 PM
95BlazerLt4wd's Avatar
95BlazerLt4wd is an unknown quantity at this point
mine are 2" im not blowning anything...
Old Apr 5, 2008 | 07:49 PM
Tippman7641's Avatar
Tippman7641 is an unknown quantity at this point
*DELETED*
please refrain from enciting arguments.
-aaron
Old Apr 5, 2008 | 09:16 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
ORIGINAL: 95BlazerLt4wd
you have also only been cranked 2 inches for a short period of time....
true, you will not see any effects immediately.... the damage takes a long time....
