Lifted Bumper Bracket
Does anyone by chance have pictures of a 1st gen 3" lift bumper bracket and/or a 2nd gen 2" lift bumper bracket?
I am putting a 1st gen bl on my 2nd gen and I'm going to fab some brackets. I just want a picture of each to go by and I can't seem to find any on google.
Ok.. here they are....
This is how I lifted the rear bumper about 3".. It's just a flat bar 3.5" wide. I didn't have to drill in the frame or bumper because I used the stock holes. (I found the flat bar in the back yard so it's a bit "weathered" lol
And this is how I lifted the front bumper. Nothing fancy. I just took the bottom bumper holes and lined them up with the top holes on the frame. You're gonna need a spacer between the bumper and the frame cause the bumper has a lip on the bottom. (or you can just grind the lip off, either way it works.) I will probably eventually put a flat bar to support the top of the bumper.
I did mine similar to that as well for my first gen. I drilled and bolted the rear bumper bracket to mount on top of the frame. Then used steel plates to bolt to the frame, then to that side bracket you see in Tony's pic. That made it pretty strong. For the front I cut the frame horns off from the frame and re-welded them 3" higher. Then added bracing behind the horn back to the frame to re-gain some strength. Many ways to skin a cat!
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=31
(I'm referencing the bottom section of the page)
See #22.. It looks like you can put a spacer where those two bolts go through. So you would have to make 4 spacers all together. Two for each side. You probably won't be able to use the "bumper brace"(#19) anymore so just take that off. It looks like it might be pretty easy to raise but I'm just looking at the book. Hopefully this helps...
I'll look at my 2001 Blazer tomorrow when it's daylight and not raining. Your 1995 is about the same...
Check my last post on my build thread. 2001 jimmy sls.
I utilized the hitch but you ccan use a piece of steal instead. And weld it better then mine lol. Or you can bolt the bumper to the flat plate and bolt it to the frame.
