Lifting
i will definately post some pics come saturday......... i got the fender flares from www.pickupsupply.com ill double check the site when i get home
ORIGINAL: jdblazin
I just wanted to thank you for serving our country and welcome home.[sm=patriot.gif]
Just my opinion; I think I would want to use a little wider then stock rim with 12.5's
ok update i am currently searching for a 15x8' rim with the stock 5x4.75 bolt pattern this is what i have found so far.....i dont know the backspacing yet though
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000396327/mediaCode-ZX/appId-11269760/Pr-p_CATENTRY_ID:10000039632711269760
Even at 11.5" on a 7" rim you will get that donut or balloon look. Do you want 12.5" wide for the "stick out"look or the over all foot print? If for the look, I would suggest going with a little bit narrower tire and a rim with less backspace and this will push your tires out. You might even save some $. I personally like the black steel rim look and am currantly debating on either the American Racing AR-767 or the Cragar CRR3425734. Good luck man!
Check out www.synergyoffroad.com for wheels for your truck. They have wheels for your truck with the correct backspacing. I would def go with a 8" wide wheel.
well i already ordered the ones without the back-spacing before i seen those....worse comes to worse ill sell locally and re-order the ones from synergy with the 4.5 back-spacing....oh well what can you do.......im sure everthing will work out...i did order some wheel spacers 5/16th thick maybe that will lend a helping hand we will see I STILL HAVE NOT EVEN STARTED THE PROJECT YET......saturday ill get it over to a lift bay at the auto craft center on fort drum new york. i will start with the suspension lift. they have ASE certified mechanics there to hand assistance. they already said they would do the little bit of welding involved at no charge.
