a little help
i have been confused with the t-bar..i know you can crank only like 1.5 which i have done..but i am confused with how it actually works as a suspension unit..i look at it and just cant figure it out i dont see how the keys work or anything..so if any one could explain what they know
The torsion bar is a spring. It applies force through resistance to twisting. By rotating the fixed end of the torsion bar, you lift/lower the truck depending on which way you rotate it. Tighten the adjustment bolt and you lift the front. Loosen it and you lower.
Torsion keys re-index the bar, effectively putting more twist into the bar for "more" lift adjustment. The problem with indexed keys is that there is a limit to how far you can safely go. This limit is attainable with simply tightening the adjusting nut with the stock keys.
I don't understand the keys bit.
I removed the T-bars from some wrecks & just used an 18mm (I think) spanner. OK, at this point it was only the chassis's & we had them flipped over.
Without going out in the rain & sliding under my truck, is there something covering it?
