My Truck
Here it is, its a 1995 Blazer LT 4dr 4wd if you couldn't tell... lol. I baught her for $750 with brand new toyo open country a/t. It needed a pitman arm, idler arm, ball joints, front driveshaft seal, and a hub for the front right tire. Oh, can't forget the motor mount i have sitting on my back seat. Here she is stock.
Here she is with the 2" PA Body lift.
I also have 2" shackles sitting here in front of me and plan on doing a tbar crank. Also my 33" Toyo Open Country M/T's that came today. They will be mounted on the Cragar Soft 8's that are sitting in my bedroom.
I am aware that i will need massive fender trimming. The truck is pretty much in ship shape other than a few minor things that are more pet peeves. my rear bumper is slightly bent for some odd reason, i have a patch of surface rust on my hood and on my driver side passenger door. In the future i would like to find some zr2 fender flares and hopefully find a way to make them fit. My final plan for now is to paint/rhinoline the frame rails soon. Watch out for updates on the shackle/tbar crank! thanks for looking.[/align]
ORIGINAL: WolfPack
VERY nice! I love those Toyo M/Ts! I like the look with the body lift on too..makes it look much more truck like I think
Did you put on the BL yourself? Or pay a shop?
ORIGINAL: willjones
33's are alot to put under there. You should look at Rcars2. He has pretty much the same setup.
ORIGINAL: Millertime21
Looks good!!! 33's shouldn't be to hard to fit.
You might need to still trim your fenders.. Because when you got in reverse and turn the wheel you will hear the wheels rubbing on the fenders. I have a 6" lift with 32's and I had to modify my fenders a little.
cant wait to see it with the tires on it. I am still waiting to do a bd lift then get some tires. how did you like the open country A/ts. I hear a lot of good things about them and I am possibly going to look at getting a set of those.
