Need Help and Advice on Shackle lift and more
Hey everyone, ive got a 2001 BlaZeR2 and am getting paid tomorrow and want to buy lift shackles and do a T-Bar crank.
I have no idea what shackles to buy for my blazer though, im not going to make my own cause i dont have the skills, so i want to buy something online. What have other people used for shackles? should i buy new hardware also?
Also, what do i need to do the T-Bar crank? is it just a couple of wrenches or do i need a special tool?
i know this topic has been covered a couple times but i can't seem to find the info i need....feel free to post up links to threads that cover this info
Thanks in advance for your help!
go to the tech section (DIY) part...
it has a how-to t-bar crank with pics.
as for the shackles get the ebay ones you see in every shackle thread
hardware = put new bushings on if you can't save the old ones, or if you are interested in doing a proper install
X2 on what he said, especially the new hardware. It's not pricey & will make a world of difference in safety to say the least. Also if you don't mind a slightly stiffer ride get polyurethane bushings, they'll last a lot longer.
Hey everyone, looking into buying these shackles tomorrow what do y'all think?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
yeah they look like the standard shackles that you'd find on eBay. With the emblem they look a little different & thats cool. The pic doesn't make the material "look" like 1/4" plate, nor do the bolt holes "look" like they're 9 1/6" like they're supposed to be... probably just the way they came out in the pic is all.
i'd do the 2" shackle. i don't know if the added inch would add that much more stress or not
, also in the front you won't be able to compensate for that inch. the t-bars can only go so far before you wear like crazy, 1.5 in the front and a 2" shackle will have a little nose dive but nothing noticable, i think the 1.5" of nose dive with the 3" shackle might be more noticable, just my 2 cents
"also in the front you won't be able to compensate for that inch. the t-bars can only go so far before you wear like crazy" <--- agreed, some say they've had 2" t bar cranks & no issues, personally i wouldn't want to go that far & just for that reason
as for the nose dive - i've seen many blazers that seem to be squating/rear lower than front, mine included
yeah 3" in the rear & only 1.5" in the front would be a bit much unless you have tired springs up front or in the rear
