Need Suggestions
Old Jul 22, 2008 | 11:21 PM
ChevyRacing88's Avatar
ChevyRacing88 is an unknown quantity at this point
Default Need Suggestions
So i saw sum tires at work i wanted to get a few months ago, they are BFG Mud Terrains. I wanna put 30's or 31's on it.. What lift would be best? body lift or suspension lift? i dont wanna lift it super high, jus high enough to clear the tires. Which would b best route and the cheapest?
Old Jul 23, 2008 | 09:37 AM
AJBert's Avatar
Default RE: Need Suggestions
Body lift will be much less expensive and easier to install.
Old Jul 23, 2008 | 11:50 AM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
cheapest way is to get the 30s and no lift. second would be a body lift and some a tbar crank and som 31s(this is assumin that you stay with the stock rims)
jimmyboy
aka silveradoboy
Old Aug 10, 2008 | 02:54 AM
drtyblnd's Avatar
drtyblnd is an unknown quantity at this point
i went to the junk yard bought some stock chevy steel rims (not S-10) put almost a two inch body lift on my 91 and barely clear on 30 9.50 s the steel rims stick outat least 1.5 to 2" wider on the newer S-10 S you should clear with 31 s no problem for the most part its fender well rub you need to get away from
Old Aug 11, 2008 | 08:16 PM
jimmyboy's Avatar
thats doesnt sound like the tire problem that sounds like a wheel back spacing problem^^^^
if you have stock wheels youll fit 30s no problem
jimmyboy
aka silveradoboy
DukMan
14
May 4, 2011 03:23 AM
punxweb
Sep 15, 2008 03:43 PM
dbleon
Apr 8, 2008 02:25 AM
jphayes921
Lifting Tech
Nov 13, 2007 05:58 PM
billthegoat
Oct 16, 2006 11:32 PM
