New at this need some help!!!
Old Jun 2, 2010 | 12:58 PM
crazyfor_4wheelers's Avatar
crazyfor_4wheelers is on a distinguished road
Default New at this need some help!!!
I have a second gen blazer. I have a 2 inch body lift with 31" on there now. If i put a 2" suspension lift on it could I be able to put 33's on there and them looking good? Also I am buying wheels, I found some with a 4.5 backspace will the make the tire stick out further than stock? I is it any help would be great.
Thanks
crazyfor_4wheelers
Old Dec 5, 2010 | 11:24 PM
c1rca121's Avatar
c1rca121 is on a distinguished road
hey there, is your blazer a zr2 model?... if it is you should beable to fit 33's no problem.
if it is just a normal blazer, the tires would fit but would rub. i am not sure about the backspacing but if the wheels that your buying has more backspacing then the stock then yes they would stick out farther and the tires should fit.. in the sticky section on "lifting tech" there is a thread about all the lifts check that out
Wyatt Abshire
Jul 12, 2012 08:27 AM
davidluzader
Mar 1, 2010 10:25 AM
jjyynnxx
Nov 23, 2008 10:41 PM
scottyk
Mar 19, 2007 11:32 PM
bigjohnstud5
Jul 7, 2006 10:08 AM
