putting on rear shackles
Old Oct 6, 2009 | 08:24 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
I misworded that. I meant to say I couldnt find a 3/4 to 1/2 socket. If I would have it would of been hella easier because the power of the 3/4. I should of done a 2" over my 1 1/2. I only did a 1 1/4 crank and a had saggy butt anyways. eh.
Old Oct 7, 2009 | 02:25 AM
bandidolenny's Avatar
Next comes the expensive stuff like wheels and tires...
Old Nov 11, 2009 | 08:39 AM
spankyy's Avatar
spankyy is an unknown quantity at this point
would i be able to get 31 on it with just 2 in lift like that
Old Nov 11, 2009 | 02:11 PM
No, you would need a body lift also.
Old Nov 11, 2009 | 10:08 PM
spankyy's Avatar
well darn wat size can i fitt then lol
Old Nov 13, 2009 | 09:57 AM
Viperguy's Avatar
Viperguy is an unknown quantity at this point
Benedict, could you get a couple of measurements from the top of the rim up to the fender for both the front and rear. I was curious as to what the measurements were because I like the way it looks and I want mine to turn out the same way. Thanks
Viperguy
Old Nov 14, 2009 | 12:54 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Mine fits 31's on a 2 inch shackle/torsion lift with minor trimming. I rub on the frame at full turn. Nothing a little bead welded on the stops wont fix.
Old Nov 18, 2009 | 02:45 PM
Viperguy's Avatar
Yeah, I don't have issues with the tires rubbing because I've got 30x9.5's but my blazer sits about an inch lower in the front than the back, stock. When I measured from the center of the wheel up to the fender, the front is at 18.5" and the rear is at 19.5". I wasn't sure what anyone else's measurements were for that. Mine does have the HD suspension and trailering package so I wasn't sure how that affected the rear height.
Viperguy
Old Nov 19, 2009 | 01:18 AM
BlaziNator's Avatar
I measure from the top of the rim. 12" front, 12.75" rear.
Old Nov 19, 2009 | 06:40 AM
Sisk's Avatar
I don't see why you couldn't fit 31's with this lift. You would have some rubbing issues at full lock probably, but I would be inclined to think they would fit.
