putting on rear shackles
Old Jan 10, 2010 | 01:59 PM
  #31
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
I only rub when I'm turning and going over a bump. wheel spacers will make ur tires rub more. If you have stock rims and do what I did 31's shouldn't rub at all. I have aftermarket rims and they stick out further than stock this is why I am faced with some rubbing
do you know if zr2 rims with 31s would rub even if i did the t-bar crank and the shackles? i got a regular blazer and was thinking of swapping my rims out for zr2 rims.
Old Jan 10, 2010 | 06:54 PM
  #32
Benedict1337's Avatar
there is no difference. zr2's wheels stick out further than stock blazers because the frames are different
Old Jan 10, 2010 | 07:10 PM
  #33
Banned
alright
Old Jan 11, 2010 | 10:07 AM
  #34
blajeans's Avatar
blajeans is on a distinguished road
I got the same idea actually! Brilliant work man!
Can I ask what are the measures on your "shackles"? How far is between this holes? Do you have any clue how much lift that differers between the holes?
Old Jan 11, 2010 | 10:31 AM
  #35
lovemy01ZR2's Avatar
lovemy01ZR2 is on a distinguished road
First of all, if you don't have a ZR2, I would use ZR2 shackles to lift the rear (ebay $40-$60), they are 10 times stronger and more durable than those skinny pieces of metal you would get at any local auto parts store (O'reilly, Advance, etc...). I just couldn't bring myself to use them. Especially if you plan on doing any off-roading. Stock ZR2 shackles are 4in from hole. But I got my shackles off Synergyoffroad.com. They 6 and 3/4" from hole to hole. $60 plus shipping. I love them!
Also when I replaced mine I didn't have to remove the bushing. I whaled and torched on mine for 4 hours. The bolts came out and I swaped the shackles out.
Old Jan 11, 2010 | 05:00 PM
  #36
warthogdriver's Avatar
i know that i am late to the party here but...i have to agree with the fact that those shackles are pretty thin. given that i used them my self, however i doubled up on each side and then bought some grade 8 hardware to cover the extra width (the bolts that came with, would not fit a doubled set).
with all this though i dont plan on doing any serious off roading
(daily driver) other than some occasional trudging through farm fields and a little trip through some woods i know of around here.
the short of it is for that price put two pairs on, what could it hurt.
if you dont want to spring for it then use your autozone points to cover the kit..its only 18.00 a set around here.
a side note: i have 31's no rubbing at all...only t-bar and the shackles.
my two cents.
Old Jan 11, 2010 | 05:15 PM
  #37
Banned
do you know if the zr2 shackles are any different then these
http://cgi.ebay.com/ebaymotors/SHACK...Q5fAccessories
Old Jan 11, 2010 | 05:18 PM
  #38
twistedmetal's Avatar
twistedmetal is on a distinguished road
im thinking of doung the same thing to my 96 what brand were the shackles n bushings n how much did it cost alltogether and also what did you do in the front
Old Jan 11, 2010 | 05:27 PM
  #39
Banned
my two cents.
what about offroad. you rub? what kind of tires
Old Jan 11, 2010 | 06:05 PM
  #40
31X15X10.5
pathfinders at
90 percent pavement driving.
but no rubbing and i have not had to trim anything fender or other wise.
stock wheels as well.
but all is well.
i have alot of pics in my album that might help you more then this.
