Rough Country 6 inch lift info
Old Jul 14, 2013 | 07:57 PM
  #41
rexazz2's Avatar
I think the kit will work fine on the 2 dr its just they they haven't actually tested it on a 2dr so it's easier to just say that it won't work. The other downside is that for anyone who already has the 2.5" and cut their front diff will not be able to use the lift unless they swap in an uncut diff.
they can test on my 2dr
Old Jul 16, 2013 | 07:05 AM
  #42
sickman420's Avatar
sickman420 is on a distinguished road
I don't quite see why you would need a new diff, either... You still cut the upper mount, and trim similar to the 2.5 lift... You actually trim more off the fins. Download the pdf. The kit comes in 2 versions according to the video. Traditional torsion bar drop or a non torsion drop. The non torsion only fits extended cab pickups, but I call bull****. Non torsion drop should use a bracket for the torsion bar in the lower control arm, and we all know the suspension is the same from model to model, be it a 2 door blazer or a standard cab truck. Is imagine you would have to move the torsion bar crossmember back a few inches for the "ntd" kit. But how much? 2"? 6"? The only pdf they had to download was the torsion drop instructions.
Old Oct 8, 2013 | 01:48 PM
  #43
TheDirtyDime's Avatar
TheDirtyDime is on a distinguished road
Hey everyone, new guy here. Been reading these forums for a long time and gotten a lot of good info from them. Figured its time I join.
So i have a 2004 s-10 blazer, 4 door, 4wd. With the rough country 2.5" suspension lift and a 2" body lift. I was hoping somebody could tell me why I wouldnt be able to use the new 6" RC lift on top of my 2.5" lift. Do I jus need to replace the front diff with a stock one? Any other reasons it wont work? Solutions??
Old Oct 9, 2013 | 10:14 AM
  #44
El_Beautor's Avatar
I think that it would be possible, but you'll run into more variables and as far as I know there hasn't been anyone try it and post their results here. We just need someone to be the guinea pig and to take lots of pictures of their process to document it. Want to volunteer?
Old Oct 9, 2013 | 08:11 PM
  #45
warthogdriver's Avatar
i would contact rough country and ask them.
Old Oct 9, 2013 | 08:44 PM
  #46
Id love to volunteer haha, its going to happen either way whenever I come up with the money, currently in the process of moving into an apartment so funds are tight for now. I'm just hoping to have a rough idea of what I'm going to need to do to make it work, I think if I jus get a stock front diff from the junkyard I can make it work with some fabrication work. Id just hate to get halfway through and realize that theres more problems than I thought or that it just simply wont work. I emailed RC and asked if it would work and if not why,and what could I do to make it work. they were no help at all, had a response in about 5 minutes from a guy saying "you cant run the 6" with the 2.5" when i asked why not and what would I need to do to make it work he never responded, tried again today and still no response.
Old Oct 9, 2013 | 09:41 PM
  #47
rexmburns's Avatar
Super Moderator
When you pose the question it sounds like you are wanting to run the 6" lift along with the 2.5" lift so that is why you got no help from them. The 2.5" lift is a much simpler lift than the 6" but it requires you to cut off a portion of your front diff that is needed to use the 6" lift. So to answer your question simply yes you can replace your front diff and then would be able to install the 6" lift. Since everything except the diff bracket is bolt on on the 2.5" you would essentially be going back and starting from stock after replacing the diff. Also if you don't have your upper control arms still laying around you will need factory arms to work with the 6" geometry. When you are finished you are only going to have 6" of lift tho not 8.5". It's really not a huge deal and you could easily sell your 2.5" with the diff already modded to someone and recoup a few dollars as well I'm sure.
Old Oct 10, 2013 | 07:17 AM
  #48
Yea that makes sense. I wish i could run them both and have 8.5"! Haha thatd be sick. But thanks alot man that was exactly what i was looking for.
Old Oct 10, 2013 | 07:59 AM
  #49
rexmburns's Avatar
Super Moderator
No problem!
Old Oct 26, 2013 | 03:29 AM
  #50
dustinhxc's Avatar
dustinhxc is on a distinguished road
oh man its tempting to get this!!!!!!!
