Searching for a lift kit
Old Jun 4, 2009 | 07:13 PM
Stoggers's Avatar
Stoggers is on a distinguished road
Lamps and fuses blowing usually indicate either a bad earth (ground) or too low a fuse rating. 2x55w will require at least a 10amp but better to be a 15amp fuse. 2x100w will require at least a 20amp, better a 25amp.
Old Jun 4, 2009 | 11:36 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
who was talking about blowing fuses??
Old Jun 5, 2009 | 10:06 AM
Stoggers's Avatar
Blazerguy22 was....
Old Jun 5, 2009 | 10:10 AM
mikeinwi's Avatar
ahh good point i skipped right over that.
Old Jun 13, 2009 | 11:34 AM
blazerguy22's Avatar
well thanks guys still cant figure the fuse problem out but im gonna be lifting the body on my truck next week the cheep way hockey pucks ftw
Old Jun 13, 2009 | 02:59 PM
NVANZEE's Avatar
what are you gonna do with the bumpers. IMO its not worth it to go with hockey pucks. Cause by the time you buy the pucks and all new harware your not saving that much. Plus your bumpers are still lower and its not a full 2in.
Old Jun 13, 2009 | 03:11 PM
actually hockey pucks are exactly one inch thick and ill find a way to relocate the bumpers my dad owns a body shop so i got a **** ton of scrap steel laying around i can use to make my own brackets
Old Jun 13, 2009 | 03:19 PM
NVANZEE's Avatar
so your going to stack two together? and you will still need to get new bolts for the body.
Old Jun 13, 2009 | 03:23 PM
yeah i know il need new body bolts idk if im gonna o tha or not i want to but idk im also trying to figure out what size tires i can put under tha to fill the wheel wells
Old Jun 13, 2009 | 03:33 PM
mikeinwi's Avatar
with 2" of lift on a 2wd drive youll be able to fit 30's for sure but i think you might have to do some minor trimming for 31's
