Shackle lift on top of a body lift
Old Mar 15, 2011 | 10:33 AM
njerrils05@gmail.com's Avatar
njerrils05@gmail.com is on a distinguished road
yeah i did. everythings tight. I just lowered the tbars back to where they were and walla much tighter. Quick question then, if i crank the tbars will my steering just be that much looser/sloppy? or will that be taken care of with an alignment?(go to different shop than the one before obviously)
Old Mar 21, 2011 | 11:35 PM
NCSWP's Avatar
NCSWP is on a distinguished road
Originally Posted by oktain
hmmm... minor trimming? Click the link in my signature... Remember ZR2's are 2" taller than a stock Blazer and IIRC 3 inch BL's aren't available for 2nd gens. so with 1.5" + 2"... that's 5.5" taller than a stock Blazer. You may need more than "minor" trimming lol because NJ4x4Blazer rubbed 32's with a 6" lift before putting his 2" body lift on... now he can clear 33's if he's not wheeling hard.
I can see that, but apparently you can get a 3in BL for the 2nd gens. Also, there's much more room in the ZR2 fenders than a stock Blazer, right?
Old Mar 23, 2011 | 05:16 PM
neo71665's Avatar
First gen 3 inch BLs work fine under a 2nd gen, you just have to figure out how to raise the bumpers.
Old Mar 24, 2011 | 01:32 PM
NCSWP's Avatar
Originally Posted by AJBert
'02 shackles will fit on an '03. You can fit a 3" body lift on a 2nd Gen by using a 2nd Gen kit and swapping out the 2" blocks for 3" blocks. ZR2's actually sit 3" taller stock than non-ZR2's. You can run 33X10.5 or even 33X12.5 on a ZR2 with just a body lift, shackles and tbar crank.
I have 33X10.5's and have trimmed quite a bit. 95% of the time offroad I don't not rub. Only when I fully flex do I rub on the rear of all four flare. Not all four at the same time, of course, but one at a time. I could trim more or go down to 32's or just not get in situations where I flex to the max.
AJBERT, thanks so much man! EXACTLY what I was looking for. You said you rubbed when fully flexed; do you have your swaybars off? What size bodylift are you running? what's your shackle specs? Also, are you over +1.25 from stock on your T-bar crank? Thanks for the help!
Old Mar 24, 2011 | 11:28 PM
AJBert's Avatar
I rub just very minor up front and rear with either my sway bar disco'd or not. I've have a 2" body lift, 2" shackles and tbars cranked 5 turns or about 1.25". I could sand/grind down the flares easily, and may do that eventually, but I very seldom fully max out the flex when offroad.
That being said, I'll probably do it before long.
Old Sep 20, 2011 | 02:56 PM
_HeC_'s Avatar
_HeC_ is on a distinguished road
anyone have some pics with shackle/tbar and BL? i just got my jimmy yesterday and ordering my shackles tomorrow and have been thinking about a 2" BL aswell
hows the hardware that comes with the ebay shackles? i kinda picture them being crap and should maybe spend $5-10 on hardware from Facca Fasteners and know the bolts wont break
Old Sep 24, 2011 | 11:20 AM
NCSWP's Avatar
TONS of people on here have pics of that, just look around.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
wills-07
Lifting Tech
Dec 19, 2010 07:09 PM
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
uncle larrys oranges
Lifting Tech
Feb 1, 2010 12:18 AM
90blazinchevy
Oct 5, 2007 01:52 PM
