Is a shackle a shackle?
Old Mar 16, 2013 | 07:01 PM
FIVEHORSE's Avatar
FIVEHORSE is on a distinguished road
Default Is a shackle a shackle?
I'm looking to do some suspension repairs here pretty soon and figure I'll add some lift shackles and crank my torsion bars while I'm in there. The question i have is this...Is one lift shackle as good or better than any other? I've been looking around and the prices vary anywhere from $35 all the way up to almost $90. here are some links to a couple i've found.
82-04 Chevy S10 / Blazer 2" Lift Shackles
Krypton Fabrications - Products - 88-04 S10/Blazer Lift Shackles
I don't want to spend a fortune on one if the cheaper ones will accomplish the same thing with no drawbacks. I don't intend on doing any serious off roading apart from getting a little adventurous while camping or something. Oh, and i have a 2000 4-door LS 4x4. i plan on getting it on 31's sometime in the future, hence the lift. Any guidance would be greatly appreciated. Thanks!
Old Mar 16, 2013 | 08:22 PM
jdespain's Avatar
IMHO, I have used the $20 set from Advanced Auto, and was extremely satisfied with them. They were basically two 1/2" flat plates of stainless steel with different holes (depending on how much lift, 2/3", you want). I used a third bolt and a spacer in the middle holes for some extra strength even though it was not neccessary. Will be buying the exact same set within the next couple weeks to use on my new (to me) Blazer. Hope this helps.
Old Mar 17, 2013 | 01:46 AM
Twip's Avatar
as long as they fit. those other ones that are 80-90 just have a little extra support on them. probably not needed seeing as you are bolting them to the steel leaf springs anyway.
uncle larrys oranges
Lifting Tech
Feb 1, 2010 12:18 AM
jason1978
Nov 10, 2009 01:02 AM
flyinbrad
Suspension Tech
Jan 20, 2009 01:23 AM
streblo
Lifting Tech
Nov 16, 2007 06:04 PM
vermillion2
Jun 15, 2007 10:24 AM
