shackles and t bar
Old Jul 6, 2009 | 12:02 PM
zippy199's Avatar
zippy199 is on a distinguished road
Default shackles and t bar
i am planing on t bar cranking my blazer and i am seeing a lot of people talking about shackles. 1st what are shackles? 2nd do i need them if i t bar crank my truck? thank you. i am a super noob when it comes to this stuff. i did search.
Old Jul 6, 2009 | 12:28 PM
PyroCustoms's Avatar
PyroCustoms is on a distinguished road
shackles make your rear leaf springs connecting point lower equaling in your rear of the truck raising. shackles can be found at advanced for about 40 bucks i believe and they have 3 diff mounting points for high middle and a little bit of raise. But be careful with doing the fron t bar no more then 4-5 cranks if you need to do your front you can get the clamps from advanced that seperate your cprings of the big rubber groumets
Old Jul 6, 2009 | 06:47 PM
AJBert's Avatar
Well...almost...
Shackles raise your rear end because they are longer than the stock shackles that are currently on your truck. They do not make the "connecting" points higher or lower on the leaf spring, they increase the height between the rear of the leaf spring and the frame.
Also, not all tbar cranks are the same across all trucks. Rule of thumb is one full turn of the adjusting bolt in the clockwise direction will give you 1/4" rise, give or take depending on the condition of your tbars. MOST folks can get by fine with 1.5" of tbar manipulation without adverse affects to the front end, others can get as much as 2" before the front end starts eating itself. Most importantly, if you crank your tbars make sure you get an alignment as soon as possible.
Not sure what clamps you are talking about need to separate the spring from the grommet, though. That is a new one on me.
Do a quick search and you should find a step by step to very easily do a tbar crank that requires no more than a socket and ratchet, though I highly recommend getting the front end in the air on jackstands when doing it.
Old Jul 7, 2009 | 09:40 PM
my bad on the info ive been doing a little research myself and im still trying to get the hang of the differences and what everything does. ive only had my blazer for a week now still learning. I also have a 2wd so im confused on if i want to go big or go home or go low n go slow =(?/ decisions decisions
Old Jul 9, 2009 | 03:08 PM
bandidolenny's Avatar
These are lift shackles...
http://www.tellico4x4.com/index.php/...4281_4742_3361
I would just do the torsion bars first and see how it sits... if it sits level enough, some people don't even bother with the rear.
Old Jul 10, 2009 | 08:33 AM
zippy199's Avatar
that's what i am, afraid of because the truck already has a lean to the passenger side. what could that be?
Old Jul 10, 2009 | 10:28 AM
oktain's Avatar
Could be a weak/broken leaf spring, weak torsion bar, lots of stuff, it's definitely suspension related though, unless you have something real heavy hiding in the panels on the passener side lol.
Have you bottomed the truck hard? My cousin's explorer did the same thing after he launched off a little hill (idiot) and it turned out to be bent control arms in the front suspension.
Old Jul 10, 2009 | 11:17 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
I got my shackles from www.synergyoffroad.com. It's run by one of our Blazer Forum members.
Old Jul 11, 2009 | 08:04 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
i made my shakles and installed my lift earlier today
it can be a lot of work and if i had it to do again i'd probably have someone else do it lol.
Dave43609
Lifting Tech
Mar 30, 2012 10:28 PM
filoblazer
Lifting Tech
Aug 29, 2011 06:07 AM
BigEffingHammer
Lifting Tech
May 3, 2011 07:42 PM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
Cavalier z24
Suspension Tech
Feb 22, 2009 10:08 PM
