Should I extend the drive shaft?
Old Sep 13, 2011 | 03:38 PM
Wendover's Avatar
Wendover is an unknown quantity at this point
Default Should I extend the drive shaft?
I've already completed the 6" BDS lift on my 2 door 4x4, 2005 Blazer. I notice that there is now only about 2" of the splined end of the yolk shaft that actually gets into the transfer case on the rear drive shaft. It's been like that for the the better part of a year and I haven't had any problems yet but should I get the drive shaft extended anyway? If so, how much should I extend it, assuming the rear end may now have a bit more suspension travel than stock?
Old Sep 14, 2011 | 02:12 PM
warthogdriver's Avatar
you could try 6 degree shims...maybe??
i have a 5 inch lift and wondered the same thing...
Old Sep 14, 2011 | 02:40 PM
Wendover's Avatar
Default Six degree shims.
I had actually never heard of these so I did a bit of a search on them. I guess the idea is that the shims would align the differential output flange / yolk with the drive shaft thereby adding some length to the shaft assembly and providing more insertion depth to the spline yolk into the transfer case. Is that correct?
Seems like that would take a lot of stress off of the rear U-joint as well. I'll try and get more information on this. Thanks for the advice.
Old Sep 14, 2011 | 03:10 PM
yup no problem, i bought mine at suspensionconnection (think thats right)
were cheap and worked for me. i had a slight driveline vibration problem.
Miscellaneous - 6 degree axle shims 2" wide w/3/8" center pins (pair)
i think thats what i bought...have to double check me on the width.
Blade_24k
Feb 26, 2014 03:03 PM
Clann91
Jun 14, 2012 10:52 AM
jackdough
Jan 21, 2012 10:14 AM
Tony H
Sep 7, 2010 07:45 AM
lizzj70
Jun 23, 2010 06:57 PM
