SL 6" vs TM 5"
Old Mar 21, 2008 | 06:09 PM
Logan's Avatar
Logan is on a distinguished road
Default SL 6" vs TM 5"
Been searching and trying to find as much info as possable. SL Looks like it will be in all better quaity, but pani in the *** to install compaired to TM. But TM looks like you need the SL 2" lift upper control arms so you dont have any camber problems. Im only considering these 2 kits. I deal with both suppliers at work, so I get them at cost. Any info would be great!!!
Old Mar 22, 2008 | 12:07 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: SL 6" vs TM 5"
You will be happier with the Superlift F.I.T. lift. Since it is Frame Integrated Technology (pain in the a$$ to install) it will be stronger, sturdier, and probably last longer. I believe it also has re-angled upper control arms to correct the camber angle problem. Superlift also makes some sweet skid plates to use with their F.I.T. lifts.. <my $0.02
Old Mar 22, 2008 | 10:29 AM
Logan's Avatar
Thats what I was thinking too. A bit more $$, but looks like it will be worth it. Looking at doing it mid-late summer.
Old Mar 25, 2008 | 06:33 AM
nj4x4blaze's Avatar
Here's my Superlift Build thread https://blazerforum.com/m_117938/tm.htm. Also check out the BDS 5" kits as well. They are really good too.
