some susupension questions86/87 k5
Old Feb 28, 2009 | 10:38 PM
1k5underconstruction's Avatar
1k5underconstruction is an unknown quantity at this point
Default some susupension questions86/87 k5
i have two k5 blazers an 86 k5 blazer with an auto trans and a 87 k5 with an manual trans. i am planning on lifting one of them using 4 inch leafs front and back and also 3-4 inch blocks front and back....i have the shocks, brake lines, drop down sway bar brackets, drop steering arm. what all else will i need for either the manual or auto trans blazer when i choose to put the lift on either one.
Old Feb 28, 2009 | 10:45 PM
Default RE: some susupension questions86/87 k5
CAN SOMEONE MOVE THIS TO THE RIGHT SUSPENSION FORUM??????? PLEASE SORRY ABOUT THE MISPLACEMENT....THANKS
Old Mar 1, 2009 | 09:11 AM
For 7-8 inches of lift, you will have to get longer driveshafts. You may need to clock the transfer case and drop the back of the transfer case down a bit to lessen the angles as well...
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
ImScrewed92
May 30, 2010 12:05 PM
davidluzader
Mar 1, 2010 10:25 AM
ZLover4Life
46
Dec 22, 2008 01:01 AM
scottyk
Mar 19, 2007 11:32 PM
