tbars and shackles
Old Nov 23, 2008 | 08:25 PM
bblackz28's Avatar
bblackz28 is an unknown quantity at this point
Default tbars and shackles
alright guys i am new here and this question has probably been asked a million times. with the tbar adjustment its a couple of turns of the bolt correct? and for the shackles i can add those to the oem springs correct? how much do the shackles cost, where can i get them, and how hard is to do? oh yeah this will be happening on a 98 blazer 4x4. thanks in advance. i am happy to be apart of the forum.
Old Nov 23, 2008 | 08:34 PM
WolfPack's Avatar
Default RE: tbars and shackles
1) spot on with the tbar. 1 full turn of the bolt = .2'. It may go a little more or less depending on how worn in your bars are.
2) no problem with shackles + OE leaf packs.
3) should be about $60-90 + shipping
4) 4 Wheel Parts. Synergy Offroad and 3 Leaf Fab would normally be my first recommendation, but they are out of stock if I'm not mistaken.
5) How hard it is depends on if youve got a 2-door or a 4-door.
Old Nov 23, 2008 | 08:45 PM
bblackz28's Avatar
its a 4 door, also should i go with new stock leafs or the ones i have on now?
Old Nov 23, 2008 | 09:35 PM
NVANZEE's Avatar
if you can afford new leafs go for it but otherwise stock are fine. just FYI my cost at the dealership was 300 per side for leafs and thats with my employee discount.
Old Nov 23, 2008 | 10:01 PM
bblackz28's Avatar
yeah i have been researching a little and i think my stock ones will work good, they dont sag at all so i should be good to go. when adjusting the tbar, whats a good way to gauge how high you have gone and know that both sides are even?
Old Nov 23, 2008 | 10:06 PM
NVANZEE's Avatar
do a few cranks at a time. then drive it a little to make sure they settle were they are supposed to. Then measure each side and do it again if you need to. also you dont want to go any higher than about 1.5"
Old Nov 23, 2008 | 10:26 PM
bblackz28's Avatar
ok once all thats done and i add a 2" bl when i do a shock upgrade, am i picking stock height shocks or compensating for the 3.5" of new lift?
Old Nov 23, 2008 | 10:29 PM
WolfPack's Avatar
Body lift doesnt affect shocks, but you can go with longer shocks to make up for the tbar crank though.
Old Nov 23, 2008 | 10:45 PM
bblackz28's Avatar
cool thx for all your help guys!
LucasMI
Feb 20, 2012 11:50 AM
lukc22
Lifting Tech
19
Mar 16, 2011 05:48 PM
taba5
May 3, 2010 07:36 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
