torsion bar?
if i cranked the t bar so i got 1 inch of lift would 30x9.5 ties still be the biggest for a stock 96 blazer 2wd? i heard of problems with your suspension if u crank the t bar. what things would u half to do to not wear out the front suspension? thanks
Brent, he was asking if he were to do that, not that he has already. Sounded like ya might have got that confused. Anyways ona factory 2wd blazer you should be able to get 30x9.5 r15's on there with no rubbing on the stock suspension. If you want a little bigger tires or just more clearance, fabtech makes a lift spindle that i believe replaces the front knuckles and gets you about 2-3" of lift.
ORIGINAL: RCars2
*edited for language*
Guys, I know the words you posted are not considered bad cuss words by most people... but IMO swearing is swearing no matter how you look at it... try to keep it as family oriented as possible.....
Thanks,
Aaron
Thanks,
Aaron
i have a 93 4x4 jimmy and there is a torsion bar in the front. i have 31x10.5s on now and it rubs in the front. i already put a 2 inch shackle lift on the rear and i need to lift the front, but how? i heard of cranking the t-bar but i dont have a clue how. i want to get 2 inches on the front to even it out. any suggestions how i can go about with this?
thank you
thank you
The t-bar connects to the bottom control arm follow it back to where you will see 2 bolts on the end of the bar. Loosen the back nut and then loosen the inside bolt to create lift in the front. Your going to want to have the front jacked up the do this!!
