torsion bar key lift
Old Feb 14, 2013 | 07:08 AM
fixrupr95's Avatar
fixrupr95 is on a distinguished road
so ive decided on flipping my upper control arms...do i need to swap sides with them like right goes on left when flipped vice versa? or just flip and keep on right and/or left side?
Old Feb 14, 2013 | 09:16 AM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
No. No sides swapping is needed
rexmburns's Avatar
Super Moderator
Please do more research you don't seem to understand what hes talking about with the ball joint flip at all! You don't move the control arms at all they are the exact same on both sides of the vehicle. A ball joint flip is moving the ball joint from its factory location (top mounted on the control arm) to the new location (bottom mounted on the control arm) To do this correctly you need to get spacers to put between the control arm and the ball joint to correct the angle.
Old Feb 18, 2013 | 12:06 PM
You don't need spacers to do that flip. I did mine with no spacers. I'll post pics of mine later
Old Mar 9, 2013 | 06:54 PM
fixrupr95's Avatar
so about to do the control arm flip and have one more question. what part am I flipping because when I took the tire off I saw like four different parts and got confused... help! the pictures I took of it are in my album
Old Mar 10, 2013 | 12:38 PM
The photos you posted are too small to see any details! :P
Anyway, here's a photo of the ball joint you need to "flip". It's done by removing the ball joint (by unbolting its small bolts on top and the big bolt on its lower tip) and installing it in its hole from underneath the control arm, instead of dropping it down in the hole. The ball joint is the one pointed at with a pink arrow in one of the photos.
Here are other photos of how my Blazer stands straight after a proper front alignment with 265-70 R15 tires.
Attached Thumbnails torsion bar key lift-finaloutput.jpg   torsion bar key lift-img_20130215_104519.jpg   torsion bar key lift-img_20130215_104837.jpg
Old Mar 11, 2013 | 04:46 PM
fixrupr95's Avatar
okay i se what your saying now and how long would this take?
Old Mar 12, 2013 | 03:12 PM
It depends on your tools (not much tools needed) and skills, but I think between 45 minutes and 2 hours max.
Old Mar 12, 2013 | 03:50 PM
fixrupr95's Avatar
any special tools needed?
Old Mar 12, 2013 | 05:02 PM
No, no special tools needed, but you'll have to put the truck on a jack-stand as you work on it and will need to use the jack to lift the steering knuckle to facilitate the installation. If you're not sure you can do it alone, don't. And don't forget to do a front alignment after you finish.
