U-Bolt size
Old Feb 2, 2013 | 10:51 AM
matt9589's Avatar
matt9589 is on a distinguished road
Default U-Bolt size
Got a set of Pro-Comp add a leaf short leafs yesterday. I plan to install them however i read tht i should just cut the old u bolts off and get new ones. What size should i be looking for with the added hight? will a 9'' long x 3'' wide work?
Old Feb 2, 2013 | 11:45 AM
newguy's Avatar
With just add aleafs the stock size should work
Old Feb 2, 2013 | 04:01 PM
abig84's Avatar
im lucky enough to have a few spring places very close by that make u bolts. so i would just put the leafs in and see if the old ones are of proper length then just bring the cut old u-bolts up to the place and say i need these
Old Feb 2, 2013 | 07:26 PM
matt9589's Avatar
I know of a place near me. thanks !
Old Feb 3, 2013 | 04:09 AM
newguy's Avatar
your local auto parts store should sell em
Old Feb 3, 2013 | 08:40 AM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
i just reuse them, never had a problem yet.
Old Feb 3, 2013 | 12:27 PM
abig84's Avatar
that gets iffy. sometimes you literally cant reuse them, they either wont come off or they will rip up the threads when you back the nuts off.
youre really NOT supposed to use them but i have also in the past, i remember going to re use a set i took off because i just had to move the truck out of the shop and the threads ripped off when i went to tighten them. but if you got a shop very close by they really arent that expensive
Old Feb 3, 2013 | 04:48 PM
matt9589's Avatar
got some new ones. i had to grind the old ones off. they were on there tight! i even used a 3' cheater bar and almost push the blazer off the jack stands lol
Old Feb 3, 2013 | 10:53 PM
Banned
ya if they dont tighten replace them forsure, i dont trust them part stores ones , i like the brnt to length spring shop ones.
maximashift
Nov 18, 2009 06:50 PM
RDR
Lifting Tech
Apr 20, 2009 03:44 PM
filtalr
Sep 21, 2007 09:13 PM
rlt7272
Suspension Tech
Mar 9, 2007 02:20 AM
clutch
Tires and Wheels
17
Feb 3, 2007 04:29 AM
