U-Bolt sizing for block lift?
Old Feb 16, 2013 | 08:16 PM
JAKT's Avatar
JAKT is on a distinguished road
Default U-Bolt sizing for block lift?
I'm looking to get a 2 inch suspension lift (front torsion cranks/blocks in the rear) done on my '00 Jimmy 4-door. I need to buy new u-bolts that are 2 inches bigger than stock but I need help with sizing/shape (round or square). I want to purchase the exact u-bolts I need for the job. Any help would be greatly appreciated, thanks.
Old Feb 16, 2013 | 09:14 PM
rexmburns's Avatar
Super Moderator
You should really look into this more! If you put blocks on your truck it will lower it due to being SUA.
Old Feb 16, 2013 | 09:30 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
do a spring over.
Old Feb 16, 2013 | 10:09 PM
rexmburns's Avatar
Super Moderator
That will give him a whole lot more than the 2" he's looking for. Best just to do either shackles (seems to be most popular) or an AAL.
Old Feb 16, 2013 | 10:38 PM
xgiovannix12's Avatar
Tbar crank with shackles is your best bet... If he adds blocks he will get way more then 2 inches of lift....
Old Feb 17, 2013 | 07:57 PM
JAKT's Avatar
The guy I found to do it says that the shackles should be left stock if blocks are added between the leafs and axle; he machines the blocks himself. He only charges $35 an hour which I think is pretty good.
Old Feb 17, 2013 | 08:07 PM
Most of us use 2 inch lift shackles... BLocks only get used with the 5 and 6 inch lift kits.
OR a sas swap. Look around and youll see.
Old Feb 17, 2013 | 08:32 PM
rexmburns's Avatar
Super Moderator
Not trying to be rude here but go ahead and pay the guy that doesn't know what he's doing to machine and install some blocks for your truck and then please come and tell us how much lift you get from it!! Seriously if you put blocks in the back of your blazer it will lower it!! The axle sits on top of the leaf spring therefore if you put a block between the axle and the spring it will raise the axle causing your truck to lower.
Old Feb 17, 2013 | 08:51 PM
Blocks only lift the rear if the axle is under the springs.... SO you put the axle under the spring and then add the block to gain more lift. You will get way more then 2 inches going this way.
Like this
Instead with shackles you get exact 2 inches to match the 1.5 inch tbar crank up front.
Old Feb 20, 2013 | 06:41 PM
JAKT's Avatar
89GMCJames
Tires and Wheels
Dec 2, 2009 04:02 PM
lil_blazin
May 10, 2009 05:20 PM
mogley99
Tires and Wheels
May 6, 2007 07:12 PM
mogley99
May 3, 2007 05:06 PM
mogley99
Tires and Wheels
Mar 25, 2007 11:00 PM
