wanting to clear 265's
Old Jun 17, 2007 | 08:40 PM
cowboy717's Avatar
cowboy717 is an unknown quantity at this point
Default wanting to clear 265's
i was wonderin what i could do to like a 96-99 blazer to clear 265's? i think i saw something a couple years back in like a field and stream that added an addaleaf in the rear and crank the torsion bars, adding like shocks and everything else.,,
also aren't extreme wheels 16" ??, will they run on a 4x4??
i'm thinking about gettin a blazer again,, kinda miss my old one
Old Jun 17, 2007 | 09:04 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: wanting to clear 265's
265? What's theprofile and rim size?
Old Jun 21, 2007 | 02:40 PM
cowboy717's Avatar
265-75-16's,, sorry
Old Jun 21, 2007 | 03:07 PM
EuroGoldLS's Avatar
Just throw in a lift block and crank the t-bars and you are all set!
Old Jun 21, 2007 | 05:14 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
What Euro said except i would suggest adding new longer travel shocks andeither adding shackles, doing an add a leaf, or doing a spring over axle conversion
Old Jun 23, 2007 | 10:56 AM
cowboy717's Avatar
where can i find a good set of cheap 16" rims to fit a blazer/jimmy? what backspacing would i have to run to not rub so bad?
does anyone have this setup?? if so please jump in
heres what i was thinking--
crank torsion bars,
add a leaf ,
longer shocks
minor finder trimming
rims,
what else would i need??
Old Jul 11, 2007 | 11:14 PM
Svenson14's Avatar
Svenson14 is an unknown quantity at this point
i believe the stock Backspacing is around5-6", so anything less than that ex 3.25" will cause the tire to stick out farter, creating a larger radius that the wheel turns on, which causes higher chance of rubbing.
you can get stock backspacing, but then your tires are still tucked under the wheel well, and it usually looks goofy, making your car look top heavy, (higher stance, but not wider)
Old Aug 22, 2007 | 05:29 PM
cowboy717's Avatar
what kinda lift do you have on that blaze?? looks good, what size tires and rims you running??
Old Aug 22, 2007 | 11:33 PM
Svenson14's Avatar
thanks, its the 6" superlift with the 32x11.5 on 15x8 procomps
93S10TahoeLT
Apr 8, 2013 09:20 PM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
Spazz
Tires and Wheels
Jan 15, 2007 08:25 PM
ivannj
Engine & Internal
Feb 9, 2006 06:02 PM
