where do you buy torsion keys the cheapest
Old Mar 30, 2011 | 08:36 PM
sharrard.'s Avatar
sharrard. is on a distinguished road
Default where do you buy torsion keys the cheapest
i have a 98 blazer and i want to do the add a leaf and torsion keys in the front but it seems to be really hard to find a vendor that has some to fit my blazer
Old Mar 30, 2011 | 09:10 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
If you are having a hard time finding them then you are not looking very hard because they are everywhere. You will get a better ride with shackles instead of an add a leaf though bro so you might wanna consider that. Without knowing if you are 4x4 or not I will assume u are. here are a few links I found in literally one search on BING. Without knowing your price range I will just post a few different options
lift kits
1-3" Torsion 2" Shackle Lift Kit S10 Blazer 4WD 82-05 - eBay (item 170535427456 end time Mar-31-11 11:20:12 PDT)
Suspension Lift by SuperLift- 1998-03 S10 ZR2 Blazer/ S15 Highrider Jimmy 4WD 2" Front / 2" Rear: Ultimate Auto Accessories
if you really want the add a leaf you can buy these and then by the torsion keys elsewhere.
Pro Comp Add-a-Leaf 13120 | 1982-98 Chevy S-10, GMC S-15 Pickup
Old Mar 31, 2011 | 04:29 PM
sharrard.'s Avatar
well where can you find just the torsion keys because everytime i look noone has the right year unless there all the same for s10 blazers. i want a sort of stiffer ride and thats what the add a leaf provides i am not apposed to shackles im just weighing my options. if the kit is easier ill just do that because its cheap i dont want to spend more then two hundred
Old Mar 31, 2011 | 04:35 PM
You really don't need keys unless your t-bars are sagging already. You can max out the lift on stock keys to the point of blowing through other suspension/drivetrain components; provided the bars are still holding up what they were designed to. If not, keys won't fix the actual problem of sagging t-bars.
Old Mar 31, 2011 | 04:46 PM
sharrard.'s Avatar
there not sagging im trying to lift the truck the cheapest way i can and torsion keys seem to be the way to go
Old Mar 31, 2011 | 04:47 PM
Have you tried just tightening in the adjusting bolt? Can't beat free! --> T-bar Crank
Old Mar 31, 2011 | 04:54 PM
sharrard.'s Avatar
hahaha i got like a 1 incher from that but idk how far i can go without messing things up ya no?
Old Mar 31, 2011 | 06:33 PM
Benedict1337's Avatar
they say you can safely do it up to 1.5" I have mine maxed and I've went through my share of front suspension parts
Old Mar 31, 2011 | 07:37 PM
New keys aren't going to correct the harsh angles in the suspension & drivetrain that result from too much lift. As Benedict stated, 1.5" is generally the acceptable limit before there are problems with wearing out the ball joints & CV shafts.
Old Mar 31, 2011 | 10:01 PM
sharrard.'s Avatar
even at stock hight i went through ball joints and cvs like crazy
CraigSnedeker
Lifting Tech
May 15, 2011 08:18 PM
papacope
Jan 28, 2010 06:21 PM
lovemy01ZR2
Lifting Tech
Oct 9, 2009 09:20 AM
tkebillybob
Jan 16, 2008 06:45 PM
sasquatchfound
Suspension Tech
22
Jul 19, 2007 12:28 AM
