wider stance
Old May 8, 2010 | 01:56 PM
  #21
clw97bravada's Avatar
clw97bravada is on a distinguished road
does the locker really make that much of a difference off road? or is it not worth the cost?
Old May 8, 2010 | 03:35 PM
  #22
Benedict1337's Avatar
depends what you do. If you try and go through deep mud, are climbing steep hills, ect. it gives you a lot better traction
Old May 8, 2010 | 05:08 PM
  #23
Swain's Avatar
Swain is an unknown quantity at this point
A locker in the rearend would make a huge difference offroad. Also doubles your chances of breaking something if you don't understand sometimes you just need to be pulled out though. I may install a minispool in my rig this summer, cheapest way to go without welding the spider gears and it doesn't see any mall parking lots anyhow.
Old May 9, 2010 | 09:53 AM
  #24
Yeah this is my daily driver.
Old May 9, 2010 | 08:16 PM
  #25
Swain's Avatar
You would want a locker that opens up when you let off the gas then... www.synergyoffroad.com sells them for just under $400 I do believe, and he is a great guy to deal with.
Old May 9, 2010 | 10:28 PM
  #26
WolfPack's Avatar
You could always swap in a ZR2 axle and hope the G80 hangs in there...thats what Im doing
Old May 24, 2010 | 08:29 AM
  #27
nit8690's Avatar
nit8690 is on a distinguished road
if you need to know your gear ratio look in the jocky box for the codes list the blazer had like 5 different axles they but in. the v6 usally had the 3.42 or the 3.73. the 4 cyl engines ran a 4.11 sometimes. I have a 96 blazer 4wd has the 3.42 and they work perfectly. has good acceleration but still rolls down the road at 65 at some lower rpms and it will pull as good as a fullsize truck will. I have pulled a few vehicles on trailers before with it and you would never know that it had a trailer on it. one was a old car for an ex girlfreind the other was my dads 85 dodge ramcharger. both times pulled like nothing but if I remeber right the 3.42 is a gu6 and the 3.73 is a gt4 or something like that
Old Jul 3, 2010 | 02:28 PM
  #28
davedidit's Avatar
davedidit is on a distinguished road
Did you retain the stocl lower A arm bump stops
is the rubbing on the top of the finder
or the bottom lip
Engery suspension has a universal bumo stop that is 1/2 inch taller than stock no rubbing 99 S10 Blazer
t bar crank 1 1/2 shackle in the rear
31 x 10.50 x 15 BFG AT's
TheRider91
Tires and Wheels
14
Dec 7, 2011 09:10 PM
josephdstone
Dec 4, 2010 11:05 AM
Mark_D
Suspension Tech
35
May 18, 2010 11:51 PM
Kevin.N.Odom
Feb 11, 2010 01:12 PM
Ash
Sep 18, 2008 04:03 PM
